Solobaric L7....to Vent or not to Vent.....and why?
Old Jun 21, 2003 | 10:17 AM
Synergy001's Avatar
Default Solobaric L7....to Vent or not to Vent.....and why?
Sealed or vented??? Whats the pros and cons of having a sealed L7 or a vented L7.
Old Jun 21, 2003 | 11:16 AM
vteg's Avatar
New User
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (Synergy001)
Vented, cause women like it
Vented is louder and lower, what else do you need.
Old Jun 21, 2003 | 11:21 AM
Al Bundy's Avatar
I asked the same question to a guy that works at a local stereo shop and he said because I have a hatchback, I want more sound pressure, so I should stay with my sealed box.
Old Jun 21, 2003 | 11:57 AM
Synergy001's Avatar
cool....anyone else
Old Jun 21, 2003 | 01:23 PM
vteg's Avatar
New User
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (Al Bundy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al Bundy &raquo;</TD></TR><TR><TD CLASS="quote">I asked the same question to a guy that works at a local stereo shop and he said because I have a hatchback, I want more sound pressure, so I should stay with my sealed box.</TD></TR></TABLE>
What was that guy smoking? Unless you have too many subs to build a proper ported box, sealed will not outperform for sound pressure. For a single sub setup, then there is no reason to be sealed.
EDIT: Unless you are a hard core SQ guy
Modified by vteg at 3:59 PM 6/21/2003
Old Jun 21, 2003 | 06:05 PM
SilverDc2's Avatar
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">
What he said man....single subs must be ported to sound good.
Old Jun 21, 2003 | 06:30 PM
PetroGuyX's Avatar
Vented is GOOOOOOOOOOOD
Old Jun 22, 2003 | 03:53 PM
MNturbosi's Avatar
Default Re: (PetroGuyX)
I agree that you should go with a vented box. However it must be a properly designed vented box. A vented box will play louder and lower. The reason that someone may have recommended a sealed box for a hatchback is because of port noise. If you use a well designed port (preferably with flares on both ends) it will minimize port noise and you will not even notice it. Another reason to go with a vented box is efficiency. You will get much more with less power out of a vented enclosure as well.
Old Jun 22, 2003 | 09:27 PM
GSteg's Avatar
Default Re: (MNturbosi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNturbosi &raquo;</TD></TR><TR><TD CLASS="quote">I A vented box will play louder and lower. </TD></TR></TABLE>
naturally and safely, a sealed box will play lower than a ported box (unless you tune the port to say 1hz. LOL!
Old Jun 22, 2003 | 11:52 PM
vteg's Avatar
New User
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">
naturally and safely, a sealed box will play lower than a ported box (unless you tune the port to say 1hz. LOL!</TD></TR></TABLE>
My bass cd does not hit 1hz
A sealed box probably will not outperform a well designed/tuned ported box in the audible range. It may be louder below 20 if you have a 35hz tune for example, but the sealed box gets owned from 50-20
To the original poster, ported boxes will have a faster dropoff below tuning frequency. So if you like shaking sheet metal, tune it low.
EDIT: Half asleep, sentences did not make sense
Modified by vteg at 1:27 AM 6/23/2003
Old Jun 23, 2003 | 11:57 AM
MNturbosi's Avatar
Default Re: (GSteg)
So what I should have said is that a ported box will play louder down to where it matters. The human ear can only hear on an average down to like 20Hz so anything below that is pointless. And most music will never play that low at all.
I thought what I was saying would help out the average joe. It's easier to explain it that way. You have to realize that I'm used to dealing with the morons that come into my store. Most of you on here are much smarter than they are and sometimes I forget that. My apologies.
Old Jun 23, 2003 | 02:10 PM
bad93ex's Avatar
Ported goes lower.
Old Jun 23, 2003 | 03:45 PM
toyzbus's Avatar
Ported will definitly be louder and lower, just make sure that you have a subsonic filter. I have seen many solobarics come back that were in a ported box due to the fact that they lose control below their tuning frequency.
Old Jun 23, 2003 | 11:06 PM
philly-O's Avatar
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (toyzbus)
if you are listening to music, make it sealed because it will be more musical. but if you just want it to be loud, port it. just dont forget to use a subsonic filter if you decide to port the box.
Old Jun 23, 2003 | 11:19 PM
dannyboi's Avatar
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (peichie)
I just installed an L7 in my buddies car in a ported box, a kicker pre fab, and it sounded awsome! Deep warm bass, not just loud.
Old Jun 24, 2003 | 12:48 AM
Dsmith5237's Avatar
I'm a newb and it wouldn't let me vote but I would go with a sealed box. As stated above and elsewhere, sealed performs better across the entire spectrum 200 hz- 15 hz. Anything below about 18 hz is not audible to a human easr and is only perceived as vibration to the rest of the body so all you'll get out of sub 15 hz is rattle rattle rattle from any loose part in your car without the sound of bass covering it up. Go with something that sounds good no matter what music you are playing.
Old Jun 24, 2003 | 01:06 AM
vteg's Avatar
New User
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (Dsmith5237)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dsmith5237 &raquo;</TD></TR><TR><TD CLASS="quote"> As stated above and elsewhere, sealed performs better across the entire spectrum 200 hz- 15 hz. </TD></TR></TABLE>
Put me out of my misery please
Why is this so?
Old Jun 24, 2003 | 10:22 AM
Synergy001's Avatar
thanks for the info....i believe my amp should have a subsonic filter
Old Jun 24, 2003 | 10:39 AM
GSteg's Avatar
Default Re: (vteg)
Modified by vteg at 1:27 AM 6/23/2003</TD></TR></TABLE>
my friend my friend my friend..a sealed box will extend LOWER, but won't be LOUDER. you're mixing up word man..get some coffee
Old Jun 24, 2003 | 01:53 PM
greebler's Avatar
Because Venting enclosures is Getto! We don't drive Caddy's
Old Jun 24, 2003 | 07:44 PM
vteg's Avatar
New User
Default Re: Solobaric L7....to Vent or not to Vent.....and why? (greebler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greebler &raquo;</TD></TR><TR><TD CLASS="quote">Because Venting enclosures is Getto! We don't drive Caddy's </TD></TR></TABLE>
You mispelled ghetto
A picture is worth a thousand. It may be easier for everyone to see what is happening. The following model is a 12" TDX. Blue is is 2 cubes tuned to 26, orange is 2 cubes sealed, yellow is 1 cube sealed. 20-25hz is the threshold of hearing for humans.
Old Jun 24, 2003 | 09:29 PM
Synergy001's Avatar
thanks for the info guys....but im still stuck in the middle...LOL
Old Jun 24, 2003 | 09:31 PM
vteg's Avatar
New User
Default Re: (Synergy001)
If you are building your own box, make one of each A small sealed "travel box" is nice to have.
Old Jun 25, 2003 | 06:46 AM
ATF Kuk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNturbosi &raquo;</TD></TR><TR><TD CLASS="quote">If you use a well designed port (preferably with flares on both ends) it will minimize port noise and you will not even notice it.</TD></TR></TABLE> the port that u speak of with the flares on each side, r u talking about an aeroport? vteg and i have both experienced port noise with our TDX in an aeroported box with about 1,000 watts. although it does help with some port noise, a square or rectangular wood port would be better in terms of port noise at high volumes.
Old Jun 25, 2003 | 11:39 AM
4g4me's Avatar
owned
