For those with mugen exhaust
Old Jun 21, 2003 | 02:24 AM
Gen5lude's Avatar
Default For those with mugen exhaust
The exhaust comes with 2 circular rings. One is squishy and the other is metal. I used the squishy one as a gasket between the muffler and b-pipe. I couldn't quite figure if i needed the metal one between the cat and b-pipe. I I was wondering if you guys used the metal circular ring, or just didn't use it at all.
Old Jun 21, 2003 | 06:17 AM
RAB's Avatar
RAB
Default Re: For those with mugen exhaust (Gen5lude)
I did use the metal one between the cat and b-pipe. I then drove around with it wondered about it, so I called King and they said I didn't need it. Besides it's not a clean fit anyways take it off you'll be fine, mines been off for a year now.
Old Jun 23, 2003 | 01:34 AM
Gen5lude's Avatar
There is this clanking sound comming from underneath my car. Its the noise that metal makes when its contracting. I was wondering if it could have been that I didn't use the metal ring. I'm also suspecting the heatshield because I had to jam some of it up so the piping wouldn't rub against it. Anyone experience this?
Old Jun 23, 2003 | 04:27 AM
Hndaman's Avatar
Yeah, mine clanks also - usually when I'm taking off. From what I can tell, it's hitting the heat shield. I'm probably going to just cut that small section out.
Old Jun 23, 2003 | 02:01 PM
Gen5lude's Avatar
Hndaman...i think the clanking noise you're referring to is just the exhaust rubbing against the heatshield. The noise i'm referring to is like rhythmic and fairly loud. It happens when i'm driving and for a little while after i turn off my car.
Old Jun 23, 2003 | 05:11 PM
Final Flash's Avatar
Had mine for a year and no "clanking"; first I've ever heard of it...
Old Jun 23, 2003 | 10:03 PM
Gen5lude's Avatar
Default Re: For those with mugen exhaust (Final Flash)
How was the fitment of your mugen? Was the piping rubbing against the heatshield?
Old Jun 23, 2003 | 10:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gen5lude &raquo;</TD></TR><TR><TD CLASS="quote">How was the fitment of your mugen? Was the piping rubbing against the heatshield?</TD></TR></TABLE>
Perfect, and no it wasn't.
Old Jun 24, 2003 | 11:53 PM
Gen5lude's Avatar
Final Flash, did you use that metal ring between the cat and b-pipe?
Old Jun 25, 2003 | 04:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gen5lude &raquo;</TD></TR><TR><TD CLASS="quote">Final Flash, did you use that metal ring between the cat and b-pipe?</TD></TR></TABLE>
No, we used the other one.
sleep
18
May 14, 2004 08:05 AM
2kflamedlude
Nov 26, 2003 07:16 PM
97whitejdmludess
Jul 21, 2003 07:54 PM
piotrush
Oct 23, 2002 04:29 PM
CPR
Jul 10, 2002 08:38 AM
