Heard if i tighten my throttle cable i will get extra kick?? True or False?
if the cable is not up to spec (too loose) it possible that your WOT is not as wide open as it could be, that's all. you want to tighten it to spec, not make it extra tight. will this make you blow away 360 modena's? no.
