possible to completely remove balance shafts, not just disable them.
thanks for the links, do I understand this correctly, if you buy the plugs offered by hondaaddict in the first link, you can pull out the shafts and plug up the hole?
you also have to turn the shaft bearings around to plug up the oiling holes for the shafts.For that,you have to have the engine apart.
KCUF_DB8
Sep 16, 2008 10:48 AM
