B20B or B20Z crank in B18C5
Old Jun 20, 2003 | 04:47 AM
Andre's Avatar
Default B20B or B20Z crank in B18C5
Is it a good idea to put a B20B or B20Z crank (lightened and balanced) in a B18C5 block ?
Which rods can i use ? I am looking for rods with improved r/s ratio (rods that are longer than stock).
Old Jun 20, 2003 | 04:53 AM
sgT's Avatar
sgT
Default Re: B20B or B20Z crank in B18C5 (Andre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">Is it a good idea to put a B20B or B20Z crank (lightened and balanced) in a B18C5 block ?
B18A/B/B20B/Z cranks are the same.
Some blocks require clearancing on the oil jets.
i personally wouldnt lighten the crank at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
You would have to use b18a/b/b20b/z rods. I wouldnt worry about r:s ratio.
Power production is your first point of concern, something most people seem to forget.
Old Jun 20, 2003 | 06:16 AM
Christian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">Is it a good idea to put a B20B or B20Z crank (lightened and balanced) in a B18C5 block ?</TD></TR></TABLE> Just to extrapalate on SGT's comments a bit. Won't he experience clearance issues with the crank and the oil squirters?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">Which rods can i use ? I am looking for rods with improved r/s ratio (rods that are longer than stock).
</TD></TR></TABLE> Unless you plan on either moving the wrist pins on the pistons or adding a deckplate to the block, you will have to run LS rods. If you want to improve your R/S ratio get a smaller crank, but you'll lose power then.
Old Jun 20, 2003 | 06:43 AM
Andre's Avatar
Default Re: B20B or B20Z crank in B18C5 (Christian)
I am looking for longer rods and pistons with moved up wrist pins.
Old Jun 20, 2003 | 06:50 AM
Christian's Avatar
Contact Larry http://www.theoldone.com/components/pistons/
lunatics209
Jun 12, 2008 01:38 AM
CW96
Jan 7, 2007 04:04 PM
turbotypeR@SPEC
Dec 5, 2004 10:51 AM
turbotypeR@SPEC
Dec 5, 2004 03:38 AM
gsr98vtec
Jan 11, 2002 05:16 AM
