WHEEL BEARINGS...OR SOMETHING...
Old Jul 23, 2001 | 01:46 PM
Phat Corolla's Avatar
New User
Default WHEEL BEARINGS...OR SOMETHING...
I have a question...When I corner excessively, there is some sort of grinding-like sound from the rear right corner of the car. Now, someone told me that it might be wheel bearings wearing out. Is this possibly the case??? If so, I'd like to fix it, so is it something i can do or not?? Thanks.
Old Jul 23, 2001 | 02:09 PM
New User
Default Re: WHEEL BEARINGS...OR SOMETHING... (Teken)
All right, thanks for the quick reply, but...
what exactly am i doing when i do this? am i then supposed to replace the bearing? I had heard that they might just need to be repacked. I guess my most important question is if this is really the problem though. Is this grinding sound something you've come across? Anyways, thanks for any help you can give me.
Old Jul 23, 2001 | 02:56 PM
New User
You know, now that you mention it, I haven't checked to see if the sound is still there after I replaced my pads the other night. I'm gonna have to go do some driving... I hope maybe I fixed it when i put everything back together...
Old Jul 23, 2001 | 04:35 PM
Padronis's Avatar
Another way to figure out if it is the bearing, take a semi-hard turn to the side you think it is. example, my left rear bearing was bad and every time I took a fast or hard letft turn, it was quiet through the turn. Good luck
Old Jul 23, 2001 | 04:54 PM
Rain_man's Avatar
New User
Default Re: WHEEL BEARINGS...OR SOMETHING... (G2LSS)
Doesn't the rear have it's entire assembly replaced... the hub and bearing? I looked in the service manual and there's no instructions on how to replace a rear wheel bearing, only the front.
Old Jul 24, 2001 | 12:58 AM
Rain_man's Avatar
New User
So the hub can be removed from the hub unit bearing? Cause it sounds like it would be pretty damn expensive to replace both the hub unit bearing and hub unit!
Old Jul 24, 2001 | 08:43 AM
New User
Default Re: WHEEL BEARINGS...OR SOMETHING... (Ein)
well, I went and drove a little bit, and i didn't hear anything, so i'm thinking it might have just been a loose sheild or something. I'm hoping that is what it was, because it doesn't sound fun to mess with the bearings and such. Thanks for your help.
mafiaboy01
Honda Civic (2001 - 2005)
Jul 17, 2017 04:31 AM
dc4teg95
May 2, 2010 08:08 PM
dj-t
11
Feb 8, 2008 06:03 AM
Tzarinque
10
Oct 18, 2006 11:06 AM
kyorishin
10
Jun 15, 2006 07:15 AM
