Cat Flange sizes?
Hey,
From what I've seen in threads, it seems that althought the stock cat is a 2.25" ID, the flange size bolts up directly to a 2.5" Bpipe. Does anyone know about the other side of the cat, where it bolts up to the header, if that will bolt up to a 2.5" header as well?
Ie. Is the header flange size (not ID) the same as a JDM header?
Thanks!
Thanks!
No, the flange on the stock USDM cat. is too small to bolt to a JDM-sized header. And FWIW, the stock cat. is not 2.25" ID at either the inlet or the outlet.
MOVE OVER
Aug 10, 2006 03:43 PM
