Will I need an alignment job if I get a bigger rear swaybar?
Old Jun 19, 2003 | 04:41 PM
EricUSC's Avatar
Default Will I need an alignment job if I get a bigger rear swaybar?
I'm thinking about replacing the 13 mm rear swaybar on my Civic with a larger one. Will getting a larger rear swaybar change camber, caster, toe, or any alignment settings?
Old Jun 19, 2003 | 04:45 PM
the DR.'s Avatar
Default Re: Will I need an alignment job if I get a bigger rear swaybar? (EricUSC)
you should be fine, doesnt change any angles
Old Jun 19, 2003 | 07:41 PM
MikeSarr_GSR's Avatar
Default Re: Will I need an alignment job if I get a bigger rear swaybar? (SlicedBread)
the only time a swaybar comes into effect is when a corner is under load from twisting the frame. when you check alignment, there is no way to see this. there is not a significant change you need to make to alignment with a swaybar unless you are **** like that and are trying to do something cool with your traction for autoX or something like that.
swizz977
10
Dec 23, 2011 09:07 PM
psegs80
24
Jul 13, 2009 07:18 AM
N20civicB18
Suspension & Brakes
Feb 19, 2007 03:56 PM
revolt_allmotor
Suspension & Brakes
Nov 6, 2005 09:04 PM
Cone
Jul 21, 2002 12:12 PM
