what should my compression levels be? and what is egr?
Old Jun 19, 2003 | 04:11 PM
ixcryxblood's Avatar
Default what should my compression levels be? and what is egr?
i got a compression test done on my 92 lude h23 engine... what should be the levels of compreesion? mine are 160 psi + or - 20 %... also does anyone know what a code 12 is on a diagnostics scan? what is egr? please help
Old Jun 19, 2003 | 04:28 PM
goalieman81's Avatar
Default Re: what should my compression levels be? and what is egr? (ixcryxblood)
the code 12 you are getting is more than likely the EGR valve which is located (looking from the front of the car into the engine bay) to the left of the intake manifold near the intake tube.
As for your compressions.....i have heard that normal is about 180 psi no more difference than 25 psi/cylinder. Mine however, would give me readings of about 210 psi with one cylinder off my 35 psi. I just did a rebuild to fix the problem but have yet to perform another compression test.
Old Jun 19, 2003 | 04:43 PM
Elkins911's Avatar
Default Re: what should my compression levels be? and what is egr? (goalieman81)
EGR = exhaust gas recirculator.... or something to that effect.
Jakester9500
Mar 27, 2020 12:09 PM
OverBoostDemon
Nov 3, 2009 09:25 AM
Jos3ph
Jan 14, 2008 09:45 AM
JSpekBB4
Feb 18, 2006 05:54 PM
BLACK_DEL_SOL
Sep 20, 2004 09:08 AM
