failed emissions
Old Jun 19, 2003 | 01:40 PM
Ivan's Avatar
senior gold member
Default failed emissions
I failed emissions. they did an idle test cause they couldn't drive my car. I failed because of the hydrocarbons. I got a reading of 1944 and it should have been 220 or under. anybody have any ideas? I know I need a valve adjustment but could that be the only reason?
Old Jun 19, 2003 | 01:57 PM
94dxt's Avatar
Default Re: failed emissions (Ivan)
I doubt that's your problem, could try it though. Have a good cat? Just curious-why couldn't they drive your car?
Old Jun 19, 2003 | 02:34 PM
Ivan's Avatar
senior gold member
Default Re: failed emissions (94dxt)
the guy couldn't handle the 4puck. I don't know if the cat is bad or not. it might be pretty worn but why the high reading of hydrocarbons?
Old Jun 19, 2003 | 03:18 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">I failed because of the hydrocarbons. I got a reading of 1944 </TD></TR></TABLE>
1944 ppm of HC at idle would have me looking for a cylinder missfire. Sounds like one cylinder isn't running at all.
Old Jun 19, 2003 | 03:22 PM
Ivan's Avatar
senior gold member
Default Re: failed emissions (Chiovnidca)
they are. I checked that by disconnecting all the injectors individually. I'm thinking my cat might be shot.
Old Jun 19, 2003 | 04:22 PM
Tomek's Avatar
omg Ivan took his car to emissions Its prolly your cat dood. Did you put **** gas in it and run it pretty hard before the test? The cat works better after the car has been driven hard and lower grade gas burns quicker...if you didnt do that it should help.
Old Jun 19, 2003 | 04:51 PM
Ivan's Avatar
senior gold member
Default Re: failed emissions (AztecEJ)
I can't put **** gas in unless you want my car to blow up. I'm leaning towards the cat since my car is actually running lean everywhere else
Old Jun 19, 2003 | 08:05 PM
Ivan's Avatar
senior gold member
anybody else?
Old Jun 19, 2003 | 08:41 PM
Lord Helmet's Avatar
my car failed because of the high hydrocarbon levels too. my car at the time had 128k miles with the original cat so I just replaced it with a new hi-flow cat and my car passed. this was on a dyno and in the "high smog area" california is known for. just my .02
Old Jun 19, 2003 | 08:45 PM
Ivan's Avatar
senior gold member
Default Re: failed emissions (sleeperciv)
what was your HC level? Mine is extremely high. standard is 220 and i got 1944
Old Jun 20, 2003 | 04:24 PM
Ivan's Avatar
senior gold member
help me
Old Jun 20, 2003 | 04:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">what was your HC level? Mine is extremely high. standard is 220 and i got 1944 </TD></TR></TABLE>
I forgot the exact numbers but I do remember it was 3 or 4 times higher then a maximum limit allowed.
Old Jun 20, 2003 | 05:13 PM
Ivan's Avatar
senior gold member
so its kinda like my numbers huh? I'm replacing the cat tomorrow.
Old Jun 20, 2003 | 10:51 PM
Ivan's Avatar
senior gold member
bump
Old Jun 21, 2003 | 08:10 AM
Ivan's Avatar
senior gold member
I changed my catalytic converter even though my old one was in good condition.
Old Jun 21, 2003 | 10:37 AM
92SiB18C1's Avatar
They have emission in Japan too? I thought it's "drive what you brung" country.
Old Jun 21, 2003 | 10:52 AM
Ivan's Avatar
senior gold member
Default Re: failed emissions (92SiB18C1)
haha I'm not in japan. its a joke. I'm in IL
Old Jun 21, 2003 | 08:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">I changed my catalytic converter even though my old one was in good condition.</TD></TR></TABLE>
How much was it? Why did you replace it if there was nothing wrong with it?
Old Jun 21, 2003 | 10:42 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
How much was it? Why did you replace it if there was nothing wrong with it?</TD></TR></TABLE>it was a universal one and I did all the work(cutting and welding). It can only help and not hurt me right? I figure it had to lower some of the emissions.
Old Jun 21, 2003 | 10:51 PM
b19coupe's Avatar
1944 HC's? A new cat can only do so much; you need to fix the cause of your misfire. Compression and spark would be the first two things I checked. Then check for an extremely lean mixture, if all else is o.k. Your car must not run too well, at least at idle!
Old Jun 21, 2003 | 11:42 PM
Ivan's Avatar
senior gold member
Default Re: failed emissions (b19coupe)
what would cause a misfire? Doesn't the high hc mean its not burning all the gas right? well they only did an idle test. my idle isn't that bad. it stays pretty steady. The only thing I fixed from that day was a nipple in the intake manifold that wasn't plugged(its the nipple for the cruise but its disabled). I plugged that up and my idle is alot better. I don't think that would have cause a high hc. My car has been running lean up up top but I don't think my lack of higher flow injectors would cause the high hc's at idle
Old Jun 21, 2003 | 11:48 PM
cause of misfire: a weak coil or other ignition component.
Old Jun 21, 2003 | 11:56 PM
Ivan's Avatar
senior gold member
would a coil go out just like that? Does anybody have a pic of the coil?
Old Jun 22, 2003 | 10:11 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">what would cause a misfire? Doesn't the high hc mean its not burning all the gas right? well they only did an idle test. my idle isn't that bad. it stays pretty steady. The only thing I fixed from that day was a nipple in the intake manifold that wasn't plugged(its the nipple for the cruise but its disabled). I plugged that up and my idle is alot better. I don't think that would have cause a high hc. My car has been running lean up up top but I don't think my lack of higher flow injectors would cause the high hc's at idle</TD></TR></TABLE>
HC's are raw, unburned fuel. CO is the product of incomplete combustion-i.e. a very rich mixture.
That vacuum leak you plugged could account for a lot of your HC's, it would cause a lean misfire in one or more cylinders.
Old Jun 22, 2003 | 10:19 AM
Ivan's Avatar
senior gold member
well I have good compression. I'm getting spark in all cylinders. Would it still be my coil?
