dyno results in
I just got my car dyno'd. This is a 99 jdm type R motor that I got from b18c1_powered_si, oem jdm 4 to 1 header, oem jdm itr cat, and greddy evo exhaust. Running a mugen spec p28 by kenji. Everything else is stock. Notice the weight they put down for my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by detaude »</TD></TR><TR><TD CLASS="quote">2450 lbs?? Is that real? But awsome power man!</TD></TR></TABLE> My car weighs a lot more than that. They used an ITR's weight for the weight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DesiEg »</TD></TR><TR><TD CLASS="quote">sounds good man whats it in a LS?</TD></TR></TABLE> It's in a gsr chassis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">is that SAE corrected?
anyways, what are your next mods?
cheers
NRG</TD></TR></TABLE> im not sure whether it was corrected for elevation. I'm at over 4000 ft. above sea level. I plan on getting a hytech(renault) cat and a hytech catback. Possibly some toda As, but seeing the awesome power curves of the stock cams, I might just leave them in.
cheers
whoah that crx is whack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenDC2 »</TD></TR><TR><TD CLASS="quote">I have always wondered about the power that a Mustang dynojet makes. We have a Mustang dyno locally and it is always making low-or-high #'s. A stock CRX SI made 127!whp</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">whoah that crx is whack.
</TD></TR></TABLE> why? cause it put out high numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIroneous »</TD></TR><TR><TD CLASS="quote">my 92 integra partially gutted weighed in at 2500 flat, what the hell did you take out of your gsr?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 »</TD></TR><TR><TD CLASS="quote"> My car weighs a lot more than that. They used an ITR's weight for the weight. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">How accurate are those Mustang dynojets?
What kind of car do you drive anyways?
cheers
NRG</TD></TR></TABLE> usually mustang dyno reads lower. I drive a gsr, w/ a 99 jdm type R motor.
cheers
9civichatch3
26
Mar 6, 2008 10:41 AM
