I think I'm losing compression!!
Is there a way to check for compression at home?
Because I opened my oil cap and put my hand over it....I feel air blowing out!
I'm pretty sure that I might be losing compression because my car just started to run kinda crappy about a month ago! PLEASE help!!
Start your car and let it idle for a few minutes.
From left to right: Pull your first spark plug cap off and listen to the car idle. It should idle much lower for a second. Now put the cap back and pull out the second one and listen how this one idles. Do this with every spark plug cap. If the car idles higher in one cilinder you'll know that that cilinder has less compression.
you could also buy a compression tester (the screw in kind)and test your compression. This way you really know if you have or don't have compression in a cilinder.
Good luck
Good luck
****!! I couldnt even break the 16.1's today at the track!!
Last time I went, I ran 3 times and two of them were 16 flats!
hehehe 16 flaT.
that plug test that was stated before is actually a home test to see if your running on 3 cylinders and the plug test actually would locate the bad cylinder for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 »</TD></TR><TR><TD CLASS="quote">hehehe 16 flaT.
that plug test that was stated before is actually a home test to see if your running on 3 cylinders and the plug test actually would locate the bad cylinder for you.</TD></TR></TABLE>
yeaa..16 flat..
I want 5spd!!!! It's kinda sad how I saw a red 5spd prelude today....runnin 16.3's!!!! talk about bad driving...
yeaa..16 flat..
16 sec is what my single cam non vtec crc was running. thats a 1.6 too. are you sure your not getting your numbers wrong??? 16 sec sounds kinda slow for an h22... regardless if its auto.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 »</TD></TR><TR><TD CLASS="quote">16 sec is what my single cam non vtec crc was running. thats a 1.6 too. are you sure your not getting your numbers wrong??? 16 sec sounds kinda slow for an h22... regardless if its auto.</TD></TR></TABLE>
well yes, auto SS ludes usually run 16's BUT mine should be in the 15's AT LEAST!!!
I hate my car so much....
(yet i love it also..)
DeCoY
Jun 21, 2017 02:45 PM
vtechjunkie
Apr 20, 2010 05:52 AM
