88-91 and 92-95 d16 pressure plate are the same??
Old Jun 19, 2003 | 11:39 AM
Boosthead's Avatar
Default 88-91 and 92-95 d16 pressure plate are the same??
Does anyone know if the 88-91 and 92-95 d16 pressure plate are the same??
Since they PP bolts to the flywheel and they both use the same flywheel, I'm thinking they are. Thoughts?
Old Jun 19, 2003 | 04:01 PM
MrTodd's Avatar
Default Re: 88-91 and 92-95 d16 pressure plate are the same?? (Boosthead)
92-95 has a different pressure plate than the 89-91. Flywheels are the same on 89-95. Obviously they both have the same bolt pattern, but the 92-95 pressure plate is most likely a little stronger than the 89-91.
Old Jun 19, 2003 | 05:54 PM
Boosthead's Avatar
Default Re: 88-91 and 92-95 d16 pressure plate are the same?? (MrTodd)
I'm thinking the 92-95 is a little stronger as well, but I was really thinking that aftermarket manufacturers probably sell one PP for the 90-95.
Johnmadsen
Feb 11, 2019 07:19 AM
flipldls
Oct 18, 2009 07:26 PM
Boosthead
Jun 20, 2003 02:20 PM
