wheel bearings?
I don't know if this is the wheel bearings or not. What is happening is I get a squeaking coming from the front drivers side wheel. It is constant and squeaks faster the faster I go. But the second I touch the brakes the squeak stops and will not start up again until I let off the brakes. I have taken the brakes off and checked everything that I could see that could be causing this noise. I am about 90% positive that the bearings where replaced about 60k miles ago. I have heard of some idiots that when they put the new bearings in don't grease them. I guess some people think that the Vaseline like stuff, that is on them to keep from rusting while shipping, is grease. Like they think they come pre-packed. Thus killing the bearings fairly soon after replacing them. Does this noise sound like a bearing problem? Anyone know? Thanks!
When my wheel bearings went on my VW, I heard a grinding sound only when I turned in one direction. As I sped up, the sound definitely became louder and when braking went away. VW Stealership charged me almost $400 (Can) to repair it.
i had a similar problem / sound and everyone told me it was the wheel bearing. Once i got it to the shop though, they replace the CV joint and i was good to go. I have not had any other problems since.
try checking how much brake pad you have left. My car did the same thing, and i spent the $$$ replacing the bearing when it was still good and it ended up being the pad. I wish somebody would've saved me the 70 bucks for pads...
Dahmer
Oct 1, 2008 01:55 PM
