spark plugs..gsr/ls/r same?
You can pretty much use any spark plug, but what you have to watch out for is the gapping on the spark plug. Each model has a different gapping specs, which you can find in your owner's manual. If you are buying pre-gapped plugs then make sure you put in the right one. However, if you are buying generic plugs, then you can gap them yourself.
civic_driver
11
May 29, 2009 06:00 PM
