Timing belt job/water pump bolts
Old Jun 18, 2003 | 10:05 PM
.RJ's Avatar
.RJ
Default Timing belt job/water pump bolts
Me and a buddy of mine put a timing belt and water pump on his EG hatchcrap w/ a B18B in it tonite - is there an easier way to access the water pump bolts other than the 3/8" drive w/ a shallow socket? Those things were a royal pain in the ***, both removing and putting them back in.
Also, i picked up an electric impact from Harbor Freight ( http://www.harborfreight.com/c...46701 ) and it zinged the crank bolt off without even working hard. Definately a good investment.
Old Jun 18, 2003 | 10:57 PM
IN VTEC's Avatar
Default Re: Timing belt job/water pump bolts (.RJ)
I just grin and bear it. To break them loose I sometimes slip a 18mm or 19mm deep socket with 6"+ extension over the butt of the ratchet to use as a breaker bar.
The Chicago electric impact wrench I have doesn't do diddly on the crank pulley bolt. It's nice for suspension work.
Tina Saunders
Jan 21, 2013 10:37 PM
[713]
Dec 2, 2009 07:51 PM
Shaguar47
May 26, 2007 09:40 AM
S2KILLA
Aug 3, 2006 07:45 AM
91tegrals
Jan 16, 2004 04:13 PM
