JDM ITR quick HID question's
Old Jun 18, 2003 | 09:23 PM
capcon83's Avatar
Default JDM ITR quick HID question's
i was just wondering if i could cut and tap into the usdm wire to wire the jdm hid lights?
or do i have get it wired from the source?
Also are the guages different on the wiring harness of the usdm and jdm wire's?
if so would it hurt the hid lights or burn the wire, if i tap into wire's of different gauges?
thanks in advance
Old Jun 18, 2003 | 09:34 PM
threatcon13's Avatar
New User
Default Re: JDM ITR quick HID question's (capcon83)
i tapped into all the stock wiring.
Old Jun 19, 2003 | 09:51 AM
capcon83's Avatar
Default Re: JDM ITR quick HID question's (Threatcon13)
did anyone else do this?
Old Jun 19, 2003 | 12:28 PM
d8168055's Avatar
yup... i used USDM wires and female connector plugs to wire it up... i did have to buy some wire (for extention) to make them all fit... just use ur stock setup to their respective JDM ones, ie low=hid, hi's=hi's, and blinkers=blinkers... as for the ground, just do a common ground from all wires...
Old Jun 19, 2003 | 03:06 PM
98R-1144's Avatar
Default Re: JDM ITR quick HID question's (d8168055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d8168055 &raquo;</TD></TR><TR><TD CLASS="quote">yup... i used USDM wires and female connector plugs to wire it up... i did have to buy some wire (for extention) to make them all fit... just use ur stock setup to their respective JDM ones, ie low=hid, hi's=hi's, and blinkers=blinkers... as for the ground, just do a common ground from all wires...</TD></TR></TABLE>
tho it was suggested to me by Mike @ IPS (at least I'm pretty sure it was Mike) that it's a good idea to combine 2 ground wires (I used my original hi beam ground and low beam ground) to plug into the ground on the JDM headlight... reason is since all the bulbs INCLUDING the HID run thru that same ground, it would be better to run a "bigger" ground connection.
eG6 driver3
Dec 15, 2007 03:34 PM
Wannabe JDM
Apr 11, 2007 11:19 AM
specie
Jan 23, 2005 11:46 AM
Kimo
May 16, 2004 04:43 PM
91cvcsi
Oct 8, 2002 12:17 PM
