car wint rev past 4400 rpms!?
Old Jun 18, 2003 | 09:18 PM
jonoknut's Avatar
Default car wint rev past 4400 rpms!?
i usually post in the integra forum but i am trying to help a friend figure out what the problem is with her 2003 civic Si. Whenever she revs the car it will be normal until 4400 or so rpms, its hard to tell exactly where it stops, but it wont rev any higher. the rpms just bounce back and forth like a rev limiter would at redline, but around the 4k mark. Now i know vtec kicks in at 4400 on my gsr, but i dont know about this Si. I amlost positive it something electrical, the engine light is on. the the maintenence required one, but the check engine one. Any ideas would be grea to see what we are working with here, thanks, jon
cliff notes: car wont rev past 4400 bounces like rev limiter.
Old Jun 18, 2003 | 09:30 PM
dacaveman's Avatar
if ur at a complete stop the car wont rev past that its 5500 rpms in the type s i dont know about the si tho i dont kno a way to change it either but once u go past 5 mph then it will rev all the way to redline just read it in the owners manual its in there somewhere
Old Jun 18, 2003 | 09:39 PM
jonoknut's Avatar
Default Re: (dacaveman)
its moving in an gear so i dont know about that
Old Jun 18, 2003 | 09:49 PM
chunky's Avatar
sounds like low oil pressure to me. most likely caused by a low oil level.
that is if there is no CEL.
if there IS a CEL, take it to the dealership and have them check it out. I threw a CEL once that put my car into limp mode. I got owned by lift throttle oversteer and was going backwards in a forwards gear for a split second. I'm sure my ecu didn't like that one bit. I cleared the CEL and everything was peachy after that. 40k miles later, and it's all gravy baby.
Old Jun 18, 2003 | 10:35 PM
NONKonformyst's Avatar
Default Re: car wint rev past 4400 rpms!? (jonoknut)
I'd have to agree. Low oil pressure will cause the ecu to go into "limp" mode, but if it's throwing CELs also then I'm not sure. I'm kind of curious since its an '03 like mine. Let us know regardless.
Old Jun 19, 2003 | 06:31 AM
fireant's Avatar
Default Re: car wint rev past 4400 rpms!? (95redLUDE)
Sounds like limp mode, you probably need oil. I top mine off at least once a month (about a quarter to a half quart).
The "lite" oil we use in the K-series burns quicker.
Old Jun 19, 2003 | 06:55 AM
Todd00's Avatar
I said I don't want a title!
It's an 03 under full warranty. Take it to the dealer and let them worry about it.
Old Jun 19, 2003 | 07:34 AM
TsunamiZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonoknut &raquo;</TD></TR><TR><TD CLASS="quote">i usually post in the integra forum but i am trying to help a friend figure out what the problem is with her 2003 civic Si. Whenever she revs the car it will be normal until 4400 or so rpms, its hard to tell exactly where it stops, but it wont rev any higher. the rpms just bounce back and forth like a rev limiter would at redline, but around the 4k mark. Now i know vtec kicks in at 4400 on my gsr, but i dont know about this Si. I amlost positive it something electrical, the engine light is on. the the maintenence required one, but the check engine one. Any ideas would be grea to see what we are working with here, thanks, jon
cliff notes: car wont rev past 4400 bounces like rev limiter.</TD></TR></TABLE>
that is normal .....its a limiter to keep from over revving in nuetral .....you dont need to be revving past 4400 in nuetral anyways ...
Old Jun 19, 2003 | 08:26 AM
fireant's Avatar
Default Re: car wint rev past 4400 rpms!? (tsunami_zc)
That may be true for Integras, but I dont think it is for EP3's.
The EP3 K20A3 vtec "kicks in" at 2200 rpm. I say "kicks in", but thats actually where the economy/ultra-low emissions setting "kicks out" and normal (somewhat agressive) mode takes over. just like on vtec-E for the previous HX civics.
On the RSX-S K20A2, an agressive, traditional vtec really kicks in at 5200 rpms.
I'm citing hondata's research data: http://www.hondata.com/techk20general.html
Also, I've personally bounced mine off the 6800 rev limiter in neutral before while testing a tachometer harness in my driveway.
Lots of people have had the dealer tell them its "limp mode" due to low oil.
Old Jun 19, 2003 | 08:28 AM
eg_nezay's Avatar
I had comparable dilemma, but why should I worry about or try to fix it if its under warrany, right?
So, I took it to the dealer and it ended up being a defective fuel pump.
Old Jun 19, 2003 | 11:00 PM
80884's Avatar
Default Re: car wint rev past 4400 rpms!? (eg_nezay)
Come on now, we all know that this is a built in launch control. Think about it, why else would they do something like that? lol Stage the car, hold to floor, let clutch go, or slip. There ya go! You don't know a good thing when it happens.
Old Jun 20, 2003 | 05:29 AM
TsunamiZC's Avatar
Default Re: car wint rev past 4400 rpms!? (80884)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80884 &raquo;</TD></TR><TR><TD CLASS="quote">Come on now, we all know that this is a built in launch control. Think about it, why else would they do something like that? lol Stage the car, hold to floor, let clutch go, or slip. There ya go! You don't know a good thing when it happens. </TD></TR></TABLE>
oh yes .....Honda built it around the idea of drag racing ....
Old Jun 20, 2003 | 07:45 AM
glw's Avatar
glw
check your oil. it's probably low.
Old Jun 20, 2003 | 09:19 AM
jerky's Avatar
Default Re: car wint rev past 4400 rpms!? (glw)
oil.
Old Jun 20, 2003 | 08:22 PM
jonoknut's Avatar
Default Re: car wint rev past 4400 rpms!? (jerky)
thanks for the responses. . the oil is low. . its below the two marks. . . so i guess well see when we add oil. . . . and it happens in all gears for you who didnt read the post not just in nuetral. ..
Old Jun 20, 2003 | 10:01 PM
glw's Avatar
glw
put in 2-3 quarts and drive around for 10-15 minutes and any dash lights that came on will extinguish.
i put a few quarts of 10-40 from a gas station and the engine got very quiet and it stopped consuming oil. i'm going to go back to 5-30 but use Mobil1 synthetic at second oil change and see how that goes.
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
eknine
Jul 18, 2003 08:06 PM
jonoknut
Jun 19, 2003 12:51 PM
B18c1EKCpe
Mar 11, 2003 06:44 PM
