Question on converting my ls to ls/vtec
Old Jun 18, 2003 | 08:12 PM
IntegraLova's Avatar
Default Question on converting my ls to ls/vtec
I know that i have to replace my b18b head with the b18c head. but dont you also have to change the computer on the car to control vtec? And if i do then how much does the cpu cost? thanks in advance
(this is my first post here. hey to all)
Old Jun 18, 2003 | 08:13 PM
boostdd's Avatar
Yes you do have to change the ECU...."computer".....
Old Jun 18, 2003 | 08:15 PM
SMZ GSR's Avatar
Default Re: (boostdd)
doesn't have to be just b18c1 head...you can also use b18c5, b16a, or even b17.
and yes you must change your ECU.
Do some searching on this board and you'll find ALOT of info on Ls/vtec setups
Old Jun 18, 2003 | 08:18 PM
Default Re: (SMZ GSR)
how much do the price of the ecu usualy run for?
Old Jun 18, 2003 | 08:22 PM
Big Teggie's Avatar
Default Re: (IntegraLova)
The price varies on what ECU you want.
Search around, you can find almost anything in the archives.
Old Jun 19, 2003 | 12:13 AM
drLazy's Avatar
Default Re: (Big Teggie)
its not totally necessary to change ecu's, but it will unlock ur new motors potential more, i would just re-chip ur existing ls ecu for a higher redline, and buy a v-afc and wire that for full vtec adjustability and more control of ur fuel. theyre getting really cheap on ebay for like $225, compared to a chipped p28 or p72 for $250. also be very careful of which block u have, i beleive 90-93 ls blocks have knock sensors, but if u have a 94+ ls block they dont have knock sensors which GSR ecu's will throw a code for??
Dc2 Joe
May 23, 2007 01:03 PM
WhiteHype08
Jan 7, 2004 05:11 AM
Turb0Minnow
Aug 20, 2002 10:37 AM
