Any of you guys run a 1 Layer headgasket?
I'm about to head up to a friends house tomorrow night to remove the balance shaft belt and do a 1 layer headgasket.
I've had experience with putting 1 layer headgaskets on B series and such to raise compression a little bit, but have not done so on my beloved H series.
I was just wondering if any of you guys are running or have ran a 1 layer headgasket.
TIA.
TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB »</TD></TR><TR><TD CLASS="quote">one layer head gasket.........wow. I wouldn't believe it would hold up but then again I've never done head/block work so I dunno.</TD></TR></TABLE>
She should hold
Many of the B series my friends have ran off of bump the compresion about .5 and held just like stock.
We will hope this is the same and I'll do a write up on this once I do this.
11.1:1 CR sounds nice if it'll hold up heh.
She should hold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsludefosho »</TD></TR><TR><TD CLASS="quote">Brandon, you going up to sage's to do this?, if so, when?
sorry I can't provide any insight bro, you know more than I do.</TD></TR></TABLE>
yep, heading up there thursday night.
Hopefully it'll be all good and done by Friday night for RMR
I'll be heading up there about 9:30 PM and getting off work early.
We should meet up.
We should meet up.
On multi-layer gaskets you can remove some (1) of the inner layers. The ony way you could get the head to seal would be to use a single shim @ .010 that has sealing compound on both sides. The stock H22 head gasket has three layers, only one can be taken out to raise compression because the other two have seal compound on one side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweak »</TD></TR><TR><TD CLASS="quote">Hey Brandon, how late you staying at sage's thursdaynight. cause i might be able to miss work to help you do it.</TD></TR></TABLE>
I'm gonna head up there right after work, and probably won't come back till Friday during the day.
We may just remove the balance shaft belt for now, because I'll be racing Friday night hopefully and don't want to run into any issues at all to jeopardize the motor for now. I'll just have to do it a little later.
Thanks guys for the input guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM BB2 »</TD></TR><TR><TD CLASS="quote">I have a Spoon Sports single layer head gasket sitting here, waiting for the rest of my parts to come in before I assemble the block.
-Mike</TD></TR></TABLE>
Isn't the spoon headgasket 2 layer? cause the one that I have is 2 layer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22ek4 »</TD></TR><TR><TD CLASS="quote">
Isn't the spoon headgasket 2 layer? cause the one that I have is 2 layer.</TD></TR></TABLE>
Do you know your compression ratio by chance?
Stock@$$GSR
Oct 18, 2004 06:51 PM
igo4bmx
Sep 24, 2004 10:28 AM
paybac4223
Mar 24, 2004 03:29 PM
