Need Help - Spark Plug Holes have oil in them
Old Jun 18, 2003 | 05:55 PM
White Dragon's Avatar
Default Need Help - Spark Plug Holes have oil in them
Car - '92 Honda Accord
My brother called saying that his car was running really bad, so I told him to stop by. Pulled the plug wires, and oil was covering the base of the spark plugs, more so in #1 and it became less as you go to #4. What would cause this... valve cover gasket?
Any help is greatly appreciate!!!
Old Jun 18, 2003 | 06:04 PM
Batoutahell's Avatar
Default Re: Need Help - Spark Plug Holes have oil in them (White Dragon)
It could be as simple as leaks in the 4 spark plug grommets. How do they look?
Old Jun 18, 2003 | 06:15 PM
Cal's Avatar
Cal
Yeah, try the simple sparkplug hole rubber O rings
Hopefully that will do it.
Wouldn't be the valvecover gasket (gasket the perimeters the entire valvecover)
Old Jun 18, 2003 | 06:32 PM
Doctor CorteZ's Avatar
Default Re: Need Help - Spark Plug Holes have oil in them (Batoutahell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell &raquo;</TD></TR><TR><TD CLASS="quote">It could be as simple as leaks in the 4 spark plug grommets. </TD></TR></TABLE>
if the plugs are dry , than thats your problem , more than likely thats what it is...
Old Jun 18, 2003 | 07:18 PM
kkim's Avatar
most likely the doughnut gaskets around the plugs in the valve cover as others have said.
changed some on a 90 accord a few months back that were so hardened they looked like plastic rings instead of the soft rubber O rings they are supposed to resemble.
hope everything is going well for you.
kelly
Old Jun 18, 2003 | 08:34 PM
Default Re: Need Help - Spark Plug Holes have oil in them (kkim)
Thanks everyone, I will check it out and see if that is it.
skaternak
Oct 2, 2008 10:32 PM
caliskier
Sep 17, 2008 08:47 PM
boogeidream
Sep 30, 2006 08:35 PM
integra racr04
Jul 25, 2006 06:38 PM
dresk
Nov 11, 2003 06:19 AM
