Help: Brake System Indicator Light
Old Jun 18, 2003 | 12:58 PM
brokenCRX's Avatar
Default Help: Brake System Indicator Light
Recently my brake light on the instrument cluster remains on after I release the parking brake. It first started doing this only when I cranked the car early in the morning and it was cold out. After driving for a while(30 minutes or so), the light went out. Now the light stays on everytime I crank the car, not just on cold mornings. If the light goes out and I brake semi-hard, it will come back on! My brake fluid is not low. Anybody else ever had this happen? Any input?
Front pads: Axxis Ultiminates
Rear pads: stock
Fluid: ATS Super Blue
The front pads were installed 3 months ago(~4000 miles) and the rear pads still had plenty of pad left at that time.
Thanks for any help!
Brett
97-241
Old Jun 18, 2003 | 01:09 PM
thk's Avatar
thk
Members Only
Default Re: Help: Brake System Indicator Light (brokenCRX)
Try changing the master cylinder cap. Worked for me.
Old Jun 18, 2003 | 01:15 PM
TypeR 01 886's Avatar
Haha... I love seeing this question, its the most common bug in Integras. Its absolutely harmless.
I have had the same problem in my GS-R and now my Type-R. I learned about it when I brought my GS-R to the dealer like 3 times for it. They do the same things everytime. Replace master cylendar cap and refill fluid. It only fixes the problem for like a week or two then it does it again.
I think its just something that is wrong with the intergra and its harmless.
Just my .02c
Old Jun 18, 2003 | 01:53 PM
brokenCRX's Avatar
I will replace the cap and see if that makes a difference.
Thanks!
Old Jun 18, 2003 | 02:08 PM
uncleben's Avatar
my car is doing this exact thing right now... i'll be interested to see if that works (and only for a few weeks...)
Old Jun 18, 2003 | 02:53 PM
00R101's Avatar
Default Re: Help: Brake System Indicator Light (uncleben)
The cap on my Type R has the level sensor wires attached to it. I wonder if they have cracked or gotten caught in the threads. I bet its a continuity problem with the sensor cables.
BTW - I know you don't want to hear this because you already said the level is good, but I would put the fluid level at very near max and see if that solves the problem. My light comes on when the fluid level is slightly above the min mark.
Chilly56
Honda Civic (2006 - 2015)
Nov 23, 2019 08:46 AM
Project94TegLs
12
Jun 2, 2015 07:29 PM
ekdriven
Oct 11, 2004 09:43 PM
98type_r
Jan 3, 2003 01:41 PM
