Head Bolts
Old Jun 18, 2003 | 09:42 AM
CptMidway's Avatar
Default Head Bolts
I know as a general rule of thumb to never use head bolts after they have been used once. A friend on mine told me that use can use Honda head bolts a few times. I just wanted everyone's opinion on this, because I'm about to replace the headgasket on a friends car and the head bolts have be used.
Thanks!
Old Jun 18, 2003 | 09:49 AM
2point6's Avatar
Default Re: Head Bolts (CptMidway)
Honda head bolts can be used 3 times.
Old Jun 18, 2003 | 10:14 AM
CptMidway's Avatar
Default Re: Head Bolts (2point6)
This will technically this will be the 3rd time they are being used so they should be ok right?
Thanks!
Old Jun 18, 2003 | 11:03 AM
2point6's Avatar
I would use them.
Old Jun 18, 2003 | 11:25 AM
Aron Parsons's Avatar
You have to figure this will probably be one of the last times the head is coming off, right? Why not replace the bolts so you have no worries down the road. I'd say if you're going to do the job, do it right. Replace the head bolts.
Old Jun 18, 2003 | 11:29 AM
Kataku2K3's Avatar
Default Re: Head Bolts (Aron Parsons)
If you're worried just get some ARP head studs!!!
Old Jun 18, 2003 | 12:59 PM
Mentat Ghola's Avatar
Default Re: Head Bolts (Kataku2K3)
I looked at mine, they dont seem stretched on the end. I plan on reusing them a 3rd time.
Old Jun 18, 2003 | 01:14 PM
Nextelbuddy's Avatar
Default Re: Head Bolts (The B Man)
can i reuse the head bolts form my blown jdm 96 type r motor? i already took the head off and have the bolts set aside and i am bolting my b16 head to a gsr block and i was wanting to know if i could reuse those head studs? or do i have to buy new arp studs?
also will the type r head studs work for a b16 head on a gsr block? or do i have to get another set for like a gsr application?
Old Jun 18, 2003 | 01:26 PM
Kataku2K3's Avatar
Default Re: Head Bolts (nextelbuddy)
I don't have a problem at all with reusing head bolts... Make sure they are within spec and you'll be fine... ARP head studs are cool for high compression or boosted motors but there's no reason for them unless you either want extra strength, the cool looks while the head is off, or you just wanna replace your OE ones... As long as you're using a B18C/1/5 block go ahead and use your ITR head bolts... If you gauge them and they're out of spec, just toss some ARP head studs in... Peace
Old Jun 18, 2003 | 01:32 PM
thats great save me some money. but u mentioned "unless im running high compression" well i will be running 11:8:1 with this setup now can i still use the head studs? lol
Old Jun 18, 2003 | 01:35 PM
Kataku2K3's Avatar
Yea, 11.8:1 is cool... I should have made that clearer, I normally consider ~12.5:1+ as a high compression motor... Stock head bolts will be absolutely fine for you so long as they are within spec...
Old Jun 18, 2003 | 01:36 PM
thanx a lot i really appreciate that
Littlegreend15
Jun 3, 2005 04:41 PM
sporkcrx
Jun 30, 2003 07:13 PM
fukaintmuven
Mar 7, 2003 10:57 PM
