Adjust the steering wheel without doing another alignment?
Old Jun 18, 2003 | 12:54 AM
Faust's Avatar
Default Adjust the steering wheel without doing another alignment?
Wassup guys,
I finally was able to replace my stock steering wheel with a Momo Corse, but the wheel is crooked. When I drive straight, the wheel is turned a little to the right. Is there anyway to correct this without doing yet another alignment?
Thanks!
Old Jun 18, 2003 | 04:32 AM
Lsos's Avatar
Default Re: Adjust the steering wheel without doing another alignment? (Faust)
Take it off and put it back on straight.
Old Jun 18, 2003 | 05:20 AM
broncoman74's Avatar
From: Northwest Hills of, CT., United States of America
Default Re: Adjust the steering wheel without doing another alignment? (Lsos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">Take it off and put it back on straight.</TD></TR></TABLE>
I agree! Look on the hub where it says top and put it there. There is no way it could be crooked if your original steering wheel was straight. Just be sure when you do it that your front wheels are turned straight. Hope this helps!
Old Jun 18, 2003 | 05:24 AM
Faust's Avatar
Default Re: Adjust the steering wheel without doing another alignment? (broncoman74)
The 2 **** fit into the hub, which means that the wheel is on right. I'll have another look tonight, but I'm 99% sure that it's mounted correctly. In case it is, is there another way to straighten it?
Old Jun 18, 2003 | 07:06 AM
Lsos's Avatar
Hmmm...maybe yours is different, but in my Integra the steering wheel mounts onto splines on the steering column. You can pretty much mount the wheel on at any degree.
quirarte626
12
Jun 25, 2009 10:49 PM
ph0shizzle
13
Jan 2, 2007 07:15 PM
zeroluck
Suspension & Brakes
Jan 11, 2006 05:42 PM
jaycetan
17
Mar 26, 2005 11:19 AM
lewdude
Sep 28, 2004 10:06 PM
