Seat height >>> ITR vs. GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkGSR »</TD></TR><TR><TD CLASS="quote">Are the factory brackets the same on the USDM Type R and GSR/LS/etc.?
Anyone know how i could lower height on a factory seat?</TD></TR></TABLE>
I'm sure they are since the chassis is the same. Want lower seats? Get del Sol seats. They will sit lower plus hold you in better under hard cornering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 »</TD></TR><TR><TD CLASS="quote">
I'm sure they are since the chassis is the same. Want lower seats? Get del Sol seats. They will sit lower plus hold you in better under hard cornering.</TD></TR></TABLE>
is it the seat thats lower or the rails on the del sol?
The seats themself. I purchased a pair for my GS-R. Simply put my GS-R rails on the del Sol seats and found myself feeling 2-4" shorter in my car. Del Sol rails don't bolt in. Had to adjust all the mirrors. Now I can't see jack **** over my shoulders. Oh, I'm only 5'5".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
Now, why on earth did you want to sit lower if you're 5'5"?</TD></TR></TABLE>
pimpin it, Grandpa, pimpin it! ya heard!
That wasn't what I was after. I got them because the side bolsters hold me in better. In my GS-R seats I moved around too much on turns. Also the part under my thigh was too high and it was annoying and I wanted to do something about it. Right now I've gotten used to it though.
FWIW, I used to drive my old roommate's '99 GS-R from time to time while I still had my Hype R. The GS-R seats "sit" a good bit higher. Between seats and sunroof, I was in the headliner in his car (5" 11") but was fine in the Hype R. Got near about that same effect with the dreaded Sparco + Wedge combination in my car.
My guess = ITR/GS-R share brackets. Seats themselves are different thicknesses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">FWIW, I used to drive my old roommate's '99 GS-R from time to time while I still had my Hype R. The GS-R seats "sit" a good bit higher. Between seats and sunroof, I was in the headliner in his car (5" 11") but was fine in the Hype R. Got near about that same effect with the dreaded Sparco + Wedge combination in my car.
My guess = ITR/GS-R share brackets. Seats themselves are different thicknesses.</TD></TR></TABLE>
Good info. Thanks.
Good info. Thanks.
94-95 gsr seat lower than all other tegs over all.. 98+ seat higher..
the brackets are different.. the 98+ have the adjustments.. etc.
hope that helps.
hope that helps.
Keep in mind that the head liner in the GSR is lower than the ITR due to the sunroof. That's why the GSR seats seem higher...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reefer_bob »</TD></TR><TR><TD CLASS="quote">
Keep in mind that the head liner in the GSR is lower than the ITR due to the sunroof. That's why the GSR seats seem higher... </TD></TR></TABLE>
when i get into my friends 95 gsr its lower... when i get into my friend 96 gsr.. its a bit higher.. when i sat in 00' ls seats.. it was high as **** w/ the ***** turned down..
all cars were riding on neuspeed race springs..
so i dunno what to say..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">94-95 gsr seat lower than all other tegs over all.. 98+ seat higher..
hope that helps.</TD></TR></TABLE>
98+ have height adjustment?
True...
But it's a combination of both factors. Seat thickness + lower headliner.
True...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy_Gunns »</TD></TR><TR><TD CLASS="quote">I always thought del sol seats are a straight bolt on for the ITR....hmmm</TD></TR></TABLE>
Yep, delsol rails fit right in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 »</TD></TR><TR><TD CLASS="quote">That wasn't what I was after. I got them because the side bolsters hold me in better. In my GS-R seats I moved around too much on turns. Also the part under my thigh was too high and it was annoying and I wanted to do something about it. Right now I've gotten used to it though.</TD></TR></TABLE>
from what i remember about riding in my friend's civic with del sol seats, they didn't seem to have much side bolstering at all..overall i'm happy with the teg seats in my dinky civic..(which came with seats with 0 bolstering so anything would've worked well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">yea the bottom seat cushion can move.. it can tilt up and down on the front & rear side.</TD></TR></TABLE>
If i got 98+ rails, would it let me adjust my seat? Or is it the seat?
Thanks again for your help.
i'm not sure on that one..
sorry i can't help..
True...
But it's a combination of both factors. Seat thickness + lower headliner.</TD></TR></TABLE>
ITR seats are pretty much the same height as GSR ones with the height adjustments all the way down. fu$#ing sunroof
True...
Here's your easiest solution: You say you want to sit lower and have more bolstering........get S2k seats. They will sit about 2 inches lower and they have bolstering out the ying-yang. You will need to make minor modifications to the S2k rails to get the effect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GM2000ITR »</TD></TR><TR><TD CLASS="quote">Here's your easiest solution: You say you want to sit lower and have more bolstering........get S2k seats. They will sit about 2 inches lower and they have bolstering out the ying-yang. You will need to make minor modifications to the S2k rails to get the effect.
or some buckets
s2k seats look good...
although i'm not a fan of leather.. too slippery..
leather + bucket seat = whats the point?
</TD></TR></TABLE>or some buckets
Drinker
