throttle and intake manifold on D16z6
Old Jun 17, 2003 | 10:44 PM
JdMCiviCCupE's Avatar
Default throttle and intake manifold on D16z6
is there anyway i can get a B16 or B18 throttle body to fit on the D16.. im pretty sure my manifold would have to be matched to it.. but can u take the b16 or b18 throttle and manifold and fit it to a D16 head .. im just looking to breathe a little better ..whats my best bet?
Old Jun 17, 2003 | 11:48 PM
salbaje's Avatar
Default Re: throttle and intake manifold on D16z6 (JdMCiviCCupE)
i think you can put on Ls tb on a d16 i've heard people say that but have never seen it done. good luck
Old Jun 18, 2003 | 12:54 AM
ERA's Avatar
ERA
He's right, the ls will work for you. as far as the IM goes, if you are running a z6, swap to a y8 mani. Other than that, you don't need anything bigger for most normal apps. If you are boosted, sure, otherwise you are going to see power loss if you go too big.
Old Jun 18, 2003 | 12:55 AM
poison's Avatar
It'll fit. You will not see very much gain with that only, but it'll fit.
And swith to a Y8 manifold.
Old Jun 18, 2003 | 08:54 PM
thanks alot guys ..ive heard the Y8 is the "type R manifold" of civics or something lol .. what makes it better than the Z6 manifold?.. thanks for the info on too big is bad otherwise i woulda wasted a good couple hundred .. so i should put a D16y8 mani and a b18 throttle on that .. will it help or just be a waste..
ps. is the y8 mani gunna need to be bored out to fit the 62mm opening of the throttle.. ?
Modified by JdMCiviCCupE at 6:08 AM 6/19/2003
Old Jun 18, 2003 | 09:38 PM
ERA's Avatar
ERA
Default Re: (JdMCiviCCupE)
My opinion? Save your money, the TB isn't going to make a big enough difference to justify buying it and port matching it to the mani. If you do decide to go with it, yes, you should taper out the mani to match the TB. Spend your money somewhere else where it will make a better improvement on power.
Old Jun 18, 2003 | 09:41 PM
see the thing is my friend happens to have the LS throttle laying around and doesnt need it so i wanted to make use of it ..
Mats_A_G
Jun 9, 2014 03:15 AM
civic nation
Feb 28, 2006 05:54 PM
Ron Burgandy
15
Nov 8, 2005 01:40 PM
allmotorEG-SI
Jan 29, 2005 07:46 PM
DC2-JRSC'd
Jul 13, 2004 09:46 AM
