d16y8 on 94 civic hb
Old Jun 17, 2003 | 08:48 PM
xtremecivichb's Avatar
Default d16y8 on 94 civic hb
what do i need to install d16y8 on 94 civic hb cx model?
is it easy or hard swap?
please help!
Old Jun 17, 2003 | 08:49 PM
Eibach95Civic's Avatar
Community Builder
Default Re: d16y8 on 94 civic hb (xtremecivichb)
what the hell..i just posted that ****??
Old Jun 17, 2003 | 08:52 PM
Default Re: d16y8 on 94 civic hb (Eibach95Civic)
where? i did search but found nothing to read...
let me know
Old Jun 17, 2003 | 08:59 PM
mycvc8u2's Avatar
i am doing that swap right now but in a 93 and turbo
Petah's Avatar
You will need from the OBD1:
- P28 ECU
- PS pump
- injectors
- alternator
- Intake manifold
That is all i can think of now. But if you are good at repinning plugs, you can repin the Y8 injectors and alternator to make it work. And the reason why i said you need a intake manifold is because i just put a D16Y7 into my 92 hatch and the IACV worked differently. The D16Y8 uses a 3 wire IACV whereas the OBD1 ECU (P28) reads a 2 wire IACV. It won't run the IACV properly hence you wouldn't idle right. But mine was a D16Y7 so it might be different than the D16Y8. That is something to look into. Good Luck!
Old Jun 17, 2003 | 09:02 PM
Default Re: d16y8 on 94 civic hb (eg-six)
that's all?
Old Jun 17, 2003 | 09:06 PM
Community Builder
for the intake many..im using V-AFC controler
qpzm12
Oct 3, 2010 12:08 PM
titi_vtec
Jun 29, 2010 05:07 PM
civicb16eg
Aug 23, 2007 10:04 PM
civicb16eg
Aug 23, 2007 08:46 PM
mini-cRx
Nov 18, 2001 05:47 PM
