My New Hotness (Pt. 2)...
Old Jun 17, 2003 | 04:55 PM
SpeedFiend's Avatar
Default My New Hotness (Pt. 2)...
Finally got the new clutch in to replace my old Spoon Clutch/Flywheel combo. Its the new Exedy Hyper Single clutch...
And with my new Hyper Ground Wire set...
Old Jun 17, 2003 | 04:59 PM
Big Phat R's Avatar
Default Re: My New Hotness (Pt. 2)... (Michael)
Nice! I wonder why they bother making it look so nice when you never see it once it's installed? I mean it's like anodizing a piston - really.....
How does it compare to the Spoon unit?
uNF$@#!'s Avatar
whats the benefit of having a pp/clutch like that? blingin style?
Old Jun 17, 2003 | 05:03 PM
capcon83's Avatar
Default Re: My New Hotness (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Nice! I wonder why they bother making it look so nice when you never see it once it's installed? I mean it's like anodizing a piston - really.....
fo reals tho why?
Old Jun 17, 2003 | 05:05 PM
SpeedFiend's Avatar
Default Re: My New Hotness (capcon83)
Haven't installed the Exedy cltuch yet. I'll give a report after its in the car.
Old Jun 17, 2003 | 05:34 PM
BlueR's Avatar
Default Re: My New Hotness (Michael)
please let us know how the pedal pressure is
Old Jun 17, 2003 | 05:53 PM
RickV's Avatar
Probably because when it sits on the shelf in the shop and then when people photograph it and post it on the net it makes people think "geez that looks really sweet - I should get one of those". It's all in the marketing.
Old Jun 17, 2003 | 06:22 PM
ITR21's Avatar
Default Re: My New Hotness (RickV)
What made you chose that clutch?
Old Jun 17, 2003 | 06:24 PM
slowassR's Avatar
Default Re: My New Hotness (ITR21)
woa purple
Old Jun 17, 2003 | 06:55 PM
Tommy_Gunns's Avatar
How the fug do you install these things? I see no provision for flywheel bolts unless you can remove the pp from the flywheel.
Old Jun 17, 2003 | 07:21 PM
non-VTEC's Avatar
is the flywheel exedy as well?
Old Jun 17, 2003 | 07:38 PM
chad's Avatar
Moderator
Default Re: My New Hotness (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">please let us know how the pedal pressure is
pressure feel is normal....maybe alittle stiffer....
launching is great.... (STANDING STARTS ROAD RACING you ricers....)
engagement is rough if you don't rev match.....
clutch held with me slamming it into lower gears to slow the car at beaver run....
i will be putting one in my daily driver!
Old Jun 17, 2003 | 07:40 PM
chad's Avatar
Moderator
Default Re: My New Hotness (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">is the flywheel exedy as well?</TD></TR></TABLE>
it is a SINGLE unit...thus the name HYPERSINGLE....yes remove the allen head bolts and "flywheel" bolts up....
this unit is nice because most of the weight is located in the center of the unit!! car will rev and rev fast!!!!!!!!!!!!!
Old Jun 17, 2003 | 07:41 PM
BlueR's Avatar
Default Re: My New Hotness (chad)
chad, its in the race kaa???
****, i should jumped in and tried it...
Old Jun 17, 2003 | 08:02 PM
ITR#132's Avatar
Default Re: My New Hotness (Tommy_Gunns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy_Gunns &raquo;</TD></TR><TR><TD CLASS="quote">How the fug do you install these things? I see no provision for flywheel bolts unless you can remove the pp from the flywheel.</TD></TR></TABLE>
Huh? Did I miss something?
Flywheel bolts to crankshaft-&gt;Clutch Disk-&gt;Pressure Plate bolts to flywheel. Its like that for all clutches.
Old Jun 18, 2003 | 05:35 AM
Dr Pooface's Avatar
Default Re: My New Hotness (ITR#132)
How does the weight compare to stock?
Old Jun 18, 2003 | 06:01 AM
stRtypR25's Avatar
how much did the hyper ground wire kit cost you?
Old Jun 18, 2003 | 07:45 AM
ScaleExtric's Avatar
Default Re: My New Hotness (stRtypR25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 &raquo;</TD></TR><TR><TD CLASS="quote">how much did the hyper ground wire kit cost you?</TD></TR></TABLE>thats what Im wondering..
Old Jun 18, 2003 | 10:09 AM
SpeedFiend's Avatar
Default Re: My New Hotness (ScaleExtric)
Not much...got hooked up through a client of mine.
Old Jun 18, 2003 | 10:44 AM
B18CXr's Avatar
some kars come with these cool things called brakes....
Old Jun 19, 2003 | 05:07 AM
SpeedFiend's Avatar
Default Re: My New Hotness (B18CXr)
Clutch goes in tomorrow morning...I can't wait to get my car back.
Old Jun 19, 2003 | 05:49 AM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
Actually the HyperSINGLE name refers to it being a single clutch disk (like the Cusco/OS SuperSINGLE), as many of these JDM metal disk clutch systems can be upgraded to dual, triple or even QUAD disks
Old Jun 19, 2003 | 06:25 AM
Moe's Avatar
Moe
Default Re: My New Hotness (kengs)
It doesnt matter what board im on, i just cant escape the JDM whoreness/expertise of Kengs....
Old Jun 19, 2003 | 09:00 AM
Yellow3TypeR's Avatar
how do you think the clutch would be for a daily driver? would your leg get tired by the time you drove around the block or is it not that stiff?
Old Jun 19, 2003 | 02:46 PM
Kengs's Avatar
Default Re: (Yellow3TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellow3TypeR &raquo;</TD></TR><TR><TD CLASS="quote">how do you think the clutch would be for a daily driver? would your leg get tired by the time you drove around the block or is it not that stiff?</TD></TR></TABLE>
I tried an ACT HD/SS recently and thought it was broke because the pedal was so light (compared to the Cusco)
Biggest adjustment IMO is not the stiffer pedal, but rather the lower engagement point (and the noise).
