3G Radiator Question
Old Jul 22, 2001 | 01:13 PM
mikecel79's Avatar
Default 3G Radiator Question
Here's a quick question for you guys with 3Gs. I was under the hood today and I noticed that the radiator moves back and forth a bit. Is this normal? It won't go anywher but it's not bolted to anything on the top. On my 1G the radiator securely fastend and it doesn't move anywhere. Thanks!
Old Jul 22, 2001 | 03:08 PM
blackls's Avatar
Default Re: 3G Radiator Question (mikecel79)
There are supposed to be two bolts fastening it to the radiator support (hence the name I guess hehe).
Old Jul 22, 2001 | 07:10 PM
mikecel79's Avatar
Default Re: 3G Radiator Question (blackls)
Mine doesn't have any bolts on top attaching it to the radiator support. It only has these small "feet" on top that fit in holes in the radiator support. It moves back and forth a bit but it won't fly out. Where is it supposed to attach to the radiator support?
Old Jul 23, 2001 | 05:41 AM
bigTom's Avatar
those 2 little "feet"... those are what attatches it to your rad. support... there should be 2 srews holding them in place...(1 each)... other than that there might might be a little play in the radiator... because the hole in the "feet" is a little bigger than the ummmm.... thing that goes into them...
(im too tired... too early monday morning... i hope this helps though)
Old Jul 23, 2001 | 01:15 PM
mikecel79's Avatar
Default Re: 3G Radiator Question (ek9t)
Yeah there is just a little play in the radiator. I just wanted to make sure it was normal. Thanks!
Old Jul 24, 2001 | 10:10 PM
cyberhide's Avatar
New User
The feet are suppose to be there to give it some slight shock resistance and noise absortion.. try running a radiator and fan straight attached.. it can give you a nice hum
wdissident
Welding / Fabrication
Feb 18, 2009 07:05 PM
yz125rider21
15
Jan 7, 2008 11:42 PM
umar456
Dec 5, 2002 12:36 PM
