Shifting without the clutch?
Old Jun 17, 2003 | 12:15 PM
LazYRaCeR's Avatar
Default Shifting without the clutch?
I shifted without using the clutch a few days ago... I just want to know if this is bad for your car or not... just wondering...
Old Jun 17, 2003 | 12:18 PM
137's Avatar
137
Default Re: Shifting without the clutch? (LazYRaCeR)
its possible but will **** your tranny up bad.
Old Jun 17, 2003 | 12:21 PM
Kamin's Avatar
Default Re: Shifting without the clutch? (137)
IT WILL DESTROY YOUR TRANSMISSION
USE THE CLUTCH
Old Jun 17, 2003 | 12:29 PM
00MRSi's Avatar
Default Re: Shifting without the clutch? (SickCiv98)
USELESS. Use the clutch. If you have plenty of money and are using your tranny for "experimental" purposes then try it. Just remember it will **** up your tranny.
Old Jun 17, 2003 | 12:30 PM
blackhatchy's Avatar
Default Re: Shifting without the clutch? (00MRSi)
majority rules........
if you value your tranny, use the damn clutch pedal
Old Jun 17, 2003 | 12:31 PM
nwdave's Avatar
Default Re: Shifting without the clutch? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">IT WILL DESTROY YOUR TRANSMISSION
USE THE CLUTCH
The only time to do this is if your clutch doesn't work.
Default Re: Shifting without the clutch? (blackhatchy)
course your sn could explain why you dont use the clutch
Old Jun 17, 2003 | 12:36 PM
TheIntegraGuy's Avatar
The clutch is your friend.
Old Jun 17, 2003 | 01:28 PM
976's Avatar
976
New User
Default Re: Shifting without the clutch? (J-MiGiRL702)
I always use a clutch. However, on a rental car or when I'm messing around I only need to use the clutch for 1st gear.
Find the perfect shift point, the slide it into gear, if you grind, then you havent found the perfect shift point. So in other words, don't try it unless you know you can do it!
Old Jun 17, 2003 | 01:30 PM
WongFeihung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">course your sn could explain why you dont use the clutch</TD></TR></TABLE>
haha!! nice one.
nk2k2
Oct 11, 2006 12:50 PM
z51LS2
Apr 3, 2006 05:00 AM
I3ooS710
Dec 5, 2005 06:33 PM
dan89crxsi
Oct 12, 2004 01:32 PM
Audio28
Jun 8, 2003 03:37 AM
