New Piston Install
Old Jul 22, 2001 | 12:43 PM
Rhetoric's Avatar
Default New Piston Install
I'm planning to put Us itr pistons in my gsr with roughly 55k on the motor. I have the pistons/pins/rings and headgasket. Is there anything else I should change, bearings, etc. or is it recommended to balance out the pistons and crank? Also what is the approx. CR with Us itr pistons .030 mill on a gsr head/block? Any opinions welcomed. Thanks.
Old Jul 22, 2001 | 01:13 PM
FAST94GSR's Avatar
New User
Default Re: New Piston Install (G S R)
I would go ahead and replace all the bearings. Get your motor balanced and blueprinted. Spend the extra money and get it done right. With 30 thouands milled and usdm itr pistoin your probably lookin at 11.5:1 That is an educated guess.
Old Jul 22, 2001 | 05:19 PM
Shoe's Avatar
New User
Default Re: New Piston Install (FAST94GSR)
no more like 11 me thinks
Old Jul 23, 2001 | 10:29 AM
Go Mifune's Avatar
New User
Default Re: New Piston Install (Shoe)
i'm milled 30 thousands - brings me to approx. 10.8:1 (stock pistons, duh)
oh...
so to answer your question, i come up with 11.4:1 (too scary for me)
[Modified by Go Mifune, 12:48 PM 7/23/2001]
Old Jul 23, 2001 | 12:38 PM
Rhetoric's Avatar
Default Re: New Piston Install (Go Mifune)
10.8 with stock gsr pistons? Have you done a compression test? I think last time I had 220 all around with .030. I'm not sure what stock is though. 11.4 isn't too bad (I hope) because I am planning to use a spoon gasket with the new pistons. What do you think?
Old Jul 23, 2001 | 12:41 PM
FAST94GSR's Avatar
New User
I have usdm itr pistons and my head is milled .020 my compression checks in at 280, wanna guess what my compression is??
Old Jul 23, 2001 | 01:50 PM
Go Mifune's Avatar
New User
no compression test - there's a bunch of complex math equations i did years ago to arrive at 10.8:1.
something i just came across says "use cranking pressure readings only as a reference to detect when optimum ring seal has been achieved (break-in complete) and as sort of a "blood pressure" check periodically to detect when something is failing." uh, ok fwit.
isn't the spoon gasket 0.4x mm? 'cuz then i think you're adding another 0.4 to your compression ratio and i put you at 11.8:1 (corrected below)
fast: 280 PSI sounds scary - what are you at?
ok, spoon makes a 2Pc Headgasket 0.4mm+0.45mm thick (stock is 0.7) so 0.85 is up 0.15... i think you're lowering yourself roughly 0.3 so...
something like 11.1:1? that sound cool (if i'm even close to being right)
[Modified by Go Mifune, 3:02 PM 7/23/2001]
Old Jul 23, 2001 | 04:25 PM
FAST94GSR's Avatar
New User
I have no friggin idea what my compression is.
Old Jul 23, 2001 | 06:52 PM
gsrmin's Avatar
New User
g s r ...
get apr new head studs and.. bolts...
TravisBiggie
May 24, 2012 12:58 PM
travishoward
Dec 10, 2010 07:56 AM
mac_24_seven
11
Aug 7, 2007 02:31 PM
alex6883
Jul 24, 2006 08:32 PM
keys
May 16, 2002 10:55 PM
