Removing the front fenders
I need to remove the front fenders on my 92 cx. One side was hit, and the other has just a little ding, so I decided to replace it. Anywhoo I removed the top three screws, the 2 along the door, and the one where the mudguard usually goes, but how do I remove those 3 little plastic phillips head screws. I already broke one
Can I get a replacement from home depot?
T.I.A
Can I get a replacement from home depot? T.I.A
you can definately get those little plastic ones from a HONDA dealership. they arent much at all. or check out a junkyard. as far a removing them i usually break them out cause they are so hard to deal with once installed. hope that helps.
i just broke em and put new ones in when putting the new fenders on. They officially are impossible unless you have a special tool for removing clips. ALSO, your forgetting the bolts underneath the sideskirts. Good luck and when your putting the new fenders on remember to keep the top bolts along the engine bay slightly loose to line the bumper up with.
