Ground Controls with KYB AGX Question??
I just receive my GC and KYB AGX for my GSR. On the instructions it looks like I need to disassemble the stock shocks to reuse some parts (i.e. bump stops, etc). Do I need any other part other that what I need to take from the OEM shocks? Is there any web site with details on the install? Thanks.
You shouldn't need anything more than your stock shock/spring assembly. Everything need for the GC/KYB assembly should be in the stock one!
Don't know a website with GC/KYB install but this site has spring/shock install...
http://www.bseries.net/html/garage/spring.php
HTH.
HTH.
breaka_1_9,
Thanks a lot for that link. That's exactly what I was looking for. The specifics I can figure out. I'll definitely give it a shot
before taking my car to a shop to do the install.
Later...
Orlando
before taking my car to a shop to do the install.Later...
Orlando
I highly recommend trying the install yourself. It doesn't take a whole lot of time and if you follow those directions you are set!
The only problem you may run into is rusted suspension bolts. Those are the worst to get out and can take a lot of time to get out or fix once you shear them.
Good luck!
Good luck!
