DOHC ZC Valve Adj
Old Jun 17, 2003 | 08:27 AM
blah13's Avatar
Default DOHC ZC Valve Adj
Did a search for the valve adj specs and got
.006 - .007in - Intake
.007 - .008in - Exhaust
And on some webpage I saved a while back has
.13 - .17mm - Intake
.15 - .19mm - Exhaust
Are these correct as well as the in to mm conversion?
Old Jun 17, 2003 | 08:46 AM
Ronin Panda's Avatar
Default Re: DOHC ZC Valve Adj (blah13)
i used mm when i adjusted mine ...i set the intake to 0.13mm on all in. valves
and the exhaust to 0.15mm on all ex. valves.
so yeah that looks right to me
Old Jun 17, 2003 | 09:08 AM
keithv's Avatar
the metric conversion is:
inches * 25.4 = mm
so (with rounding)
0.005" = 0.13mm
0.006" = 0.15mm
0.007" = 0.17mm
0.008" = 0.19mm
here are the valve specs that i have gotten from my manual:
http://breaka19.netfirms.com/zc/valve_specs.htm
what i usually do is set the intake to 0.006" or 0.15mm and the exahust to 0.007" or 0.17mm.
Old Jun 17, 2003 | 09:17 AM
DJ_SaNdOz's Avatar
Default Re: DOHC ZC Valve Adj (keithv)
doe sit really matter what valve lash tool is uesd? I need to order one b/c my zc is ticking like a mug
Old Jun 17, 2003 | 09:27 AM
keithv's Avatar
Default Re: DOHC ZC Valve Adj (DJ_SaNdOz)
i use a normal feeler gauge (the straight gauge style since i can't ever find the bent gauge style that has a small enough gauge). i picked up the snap-on style valve adjustment tool from harbor frieght a while back. it def. makes things go a little bit quicker.
i've also used a screwdriver with a rachet wrench and that worked pretty good/quick, too.
Old Jun 17, 2003 | 12:08 PM
blah13's Avatar
Cool deal, thats the same chart I got saved breaka, jus checkin. Thanks.
DJ_SaNdOz's Avatar
thanks
WindyCity
Mar 29, 2007 07:28 PM
91teg
Mar 13, 2004 05:14 PM
DevineCRX
Jul 29, 2003 06:07 PM
gregv
Sep 17, 2002 01:16 AM
CimorelliCRX
Mar 8, 2002 05:35 PM
