dpfi-mpfi
Old Jun 17, 2003 | 06:26 AM
93slmdcvcsi's Avatar
Default dpfi-mpfi
I done the dpfi-mpfi swap on my 89 civic hb and everything is fine except for a hessitation during low rpm's. Does anyone know what that could be and how i can go about fixing it?
Old Jun 17, 2003 | 06:57 AM
matt j's Avatar
Default Re: dpfi-mpfi (89cvchb)
check your cylinder positioning sensor wires and make sure they arent hooked up backwards
Old Jun 17, 2003 | 07:10 AM
where is the cylinder position sensor?
Old Jun 17, 2003 | 07:37 AM
Vinceg99's Avatar
Default Re: (89cvchb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cvchb &raquo;</TD></TR><TR><TD CLASS="quote">where is the cylinder position sensor?</TD></TR></TABLE>
Its in the distributor. You used an Si or EX distributor right? Its the wires you were suppose to add from the ECU to the distributor, not sure what color they are though.
Old Jun 17, 2003 | 11:52 AM
pokemon's Avatar
blu/grn and blu/yel, pins b10 and b12 at the ECU, switch them. If they are backwards the hestitation is caused from the timing being retarded. HTH
Old Jun 17, 2003 | 03:44 PM
91civicEX's Avatar
check your dist. timing
Old Jun 17, 2003 | 04:37 PM
91civicDXdude's Avatar
you can also use the CRX HF distributor.
Old Jun 18, 2003 | 07:08 AM
tried switching the cyclinder sensor wires and still getting a hesistation, also when i am holding the throttle in the same spot during low rpms it sounds like the fuel might be cutting out or isn't getting enough
Old Jun 18, 2003 | 09:52 AM
YumVTEC's Avatar
Default Re: (pokemon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pokemon &raquo;</TD></TR><TR><TD CLASS="quote">blu/grn and blu/yel, pins b10 and b12 at the ECU, switch them. If they are backwards the hestitation is caused from the timing being retarded. HTH</TD></TR></TABLE>
won't that throw a code if they are wired backwards?
Old Jun 18, 2003 | 10:02 AM
matt j's Avatar
Default Re: (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
won't that throw a code if they are wired backwards?</TD></TR></TABLE>
sometimes it wont i drove for 3 monthes without one, then i looked at the ecu and figured it out
Old Jun 18, 2003 | 09:30 PM
matt j's Avatar
Default Re: (matt j)
is there anybody in VA that can help this guy out like personally go check the car out?
i_VTEC
17
Oct 15, 2007 10:17 AM
txq45
Apr 9, 2005 11:01 PM
JustOneOrTwoPosts
Mar 4, 2005 07:07 AM
93vtec
Mar 2, 2004 05:58 PM
