identify type s cams
Old Jun 16, 2003 | 09:45 PM
eg:R's Avatar
Default identify type s cams
i will be shortly receiveing my type s cam that i bought used, i was just wondering if some can help me identify if the cams are type s? any marks or part #'s?? just want to make sure that they are type s when they get here and not any other cams, just don't want to get rip off, thanks for the feedback
Old Jun 17, 2003 | 01:01 AM
kotetu's Avatar
Default Re: identify type s cams (jacklee)
get a set of calipers and measure the lobes.
Otherwise take this question to your local Honda dealership's parts department.
Modified by kotetu at 5:35 AM 6/23/2003
Old Jun 17, 2003 | 06:40 AM
machine4321's Avatar
Default Re: identify type s cams (kotetu)
this is a question for your local Honda dealership's parts department
why would you say that im sure there is a few ways to check to make sure
i forget the type s part number but the preludes are p13 for example
Old Jun 17, 2003 | 06:41 AM
4g4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kotetu &raquo;</TD></TR><TR><TD CLASS="quote">this is a question for your local Honda dealership's parts department.</TD></TR></TABLE>
yep because they sold a few type s's here in the states.
Old Jun 17, 2003 | 07:22 AM
eg:R's Avatar
i know that the part #'s will have p13 in it, but i'm buying them used, it will not come with any part #'s or in it's wrap bag, just wondering if there is anything that i can tell from the both type s and my stock camshaft, because from the stock gsr and b16 cams, the type r have rings engrave on the ends of the cams to tell that it is type r, so i was just wondering what mark does the type s will have that the stock h22 cam will not have to tell between the two, if anyone out there bought some type s cams or have some, your help will be thankful, thanks for the replys
Old Jun 17, 2003 | 08:48 AM
kotetu's Avatar
Default Re: identify type s cams (4g4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4me &raquo;</TD></TR><TR><TD CLASS="quote"> yep because they sold a few type s's here in the states. </TD></TR></TABLE>
The honda parts department will know if and where a part number is located. Do you think Type S cams have part numbers in a different place than stock cams? They are all manufactured in Japan anyway.
Old Jun 17, 2003 | 08:52 AM
kotetu's Avatar
Default Re: (jacklee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacklee &raquo;</TD></TR><TR><TD CLASS="quote">i know that the part #'s will have p13 in it, but i'm buying them used, it will not come with any part #'s or in it's wrap bag, just wondering if there is anything that i can tell from the both type s and my stock camshaft, because from the stock gsr and b16 cams, the type r have rings engrave on the ends of the cams to tell that it is type r, so i was just wondering what mark does the type s will have that the stock h22 cam will not have to tell between the two, if anyone out there bought some type s cams or have some, your help will be thankful, thanks for the replys</TD></TR></TABLE>
I mentioned this before, in your first post of this same question. You need to get a set of calipers and measure the height of the vtec lobes.
The height of the Type S cam lobes should be something like 1.5 mm higher(correct me if I am wrong) than your stock camshaft vtec lobes.
BoostedVtecGsr
Nov 2, 2004 01:31 PM
hondaboi187
Jul 22, 2004 10:45 AM
