Stock to ITR rear sway bar... will it bolt on/ will it be noticable?
I believe the 22 mm ITR rear sway bar will bolt on to CRXs but Im not sure. If anyone is running this bar, how do you like it? Is it a big change from the stock 17mm?
I only know of two ppl running this bar, since you have to do some custom drilling and make a custom beakes kit deal not very many ppl do it. I will be doing the same soon and only because the ST bar hits my exhuast so I want something closer to the sub frame. It should be just like the St since they are the same size, but ST has an options of how you want ot set up the bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote">I only know of two ppl running this bar, since you have to do some custom drilling and make a custom beakes kit deal not very many ppl do it. I will be doing the same soon and only because the ST bar hits my exhuast so I want something closer to the sub frame. It should be just like the St since they are the same size, but ST has an options of how you want ot set up the bar.</TD></TR></TABLE>
you always have the option of raising/lowering your exhaust hangers
dj theoretic
11
Jan 18, 2009 11:49 AM
