Crank Pulley+ power steering
Old Jun 16, 2003 | 06:42 PM
91civicEX's Avatar
Default Crank Pulley+ power steering
it all started when i was tryin to get my pulley off to swap my cam. we broke part of the pulley that runs the power steering. i didnt want to run my pulley with it unbalanced like that and i had a spare Si pulley(no power steering) so i threw that on after i finally got my bolt off. Now my car is puking ps fluid all over and i thought that a pulley "kit" from aem would actually come with a crank pulley but it didnt. so now im stuck and i can't find and underdrive crank pulleys that support power steering. Has anyone seen or does anyone have one of these pulleys? i sent an email to unorthodox to see if they carried it but they didnt reply. I want power steering back.
Vlad
Old Jun 16, 2003 | 06:45 PM
FourthGenHatch's Avatar
Default Re: Crank Pulley+ power steering (91civicLX)
Why did you take off your crank pulley to change your cam shaft?
Old Jun 19, 2003 | 08:21 PM
91civicEX's Avatar
needed to take the timing cover off to get to the timing belt tensioner.
Old Jun 19, 2003 | 08:24 PM
turbob18a1's Avatar
aem makes 'em
Old Jun 19, 2003 | 08:25 PM
altoid's Avatar
Default Re: (91civicLX)
there is a little hole in your cover to do that, it may be covered up with a black thing just pop it off and there's the bolt
Old Jun 22, 2003 | 10:55 PM
91civicEX's Avatar
damn, i hope your not right. i think you are though because taking the crank pulley off when you change the timing belt is kind of excessive. youre the first person to mension that to me though. also i talked to a guy at unorthodox racing and he said if i got a 92-95 ps pump, bracket, and pulley a 92-95 pulley will work. anyone back that up?
Old Jun 22, 2003 | 11:12 PM
TomO's Avatar
sorry to tell you, but altoid is right...there is an access hole with a plug in it to access the tensioner. Have a it helps
MoreBoost!
Jan 29, 2009 07:07 AM
EL-Driver
Aug 3, 2003 07:27 PM
jared703
Jun 8, 2001 08:31 AM
