****Crx wont start!! think its the Main Relay!!****
The car: 88 crx with b17a
The problem: car wont start up--starter turns but seems like no fuel!?
Is it the main relay?? I tryed another main relay off my bros 89 crx--still didnt start....PLEASE HELP
**BTW: Sometimes when the car would Idle low it would just die and SOMETIMEs when the car was being driven normally then put it in neutral while the car was moving the car would die???!!!
check if the fuel pump is on or if there is power going back to the fuel pump. if it is check fuel pressure by the removing the small screw on top of the fuel filter. im having that same problem right now.
Si-Samuri
29
Jun 19, 2008 05:48 PM
