New Guy
From: The Grass is allways Greener on the other side
Hey yall what's up? I am new to the board and thought I would see waht was going on with other CRX owners. I have a 90 Si. with a built GSR all motor. Just got finished putting it together and was wondering waht you think i might run.
94 GSR motor, CTR pistons, Toda B's, mild head work, and chipped ecu.
Thanks for the help.
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
dunno man a friend i know, said a dude in florida had a rusted out 88hf with a gsr h/i/e and ignition and on slicks he ran a 13.23 dunno the mph but if you have yours built you could be in 12s maybe 11s but i dunno i just have a b16a with a throttle body so, but your crx sounds tight gl at the track
the times you pull at the track are dependent on how good of a driver u r.
your setup is probably capable of running at least a 14flat. with slicks mabey a little lower.
Easiest way to find out is to run it and then tell us.
BTW next time title your thread something like b18c crx what times will I run,
or something along those lines so people can use the search function and find the thread instead of posting the same thing over again.
Also, a colon is not necessary after Old People in your signature.
deftones0817
39
Nov 2, 2004 05:38 PM
