overheating problems! please help!
Old Jun 16, 2003 | 04:49 PM
agent marlon's Avatar
Default overheating problems! please help!
My setup: y8 IM with .040" milled z6 head and y8 head gasket.
problem: overheating and overflow of backup coolant reservoir.
I've changed water pump and thermostat and even drove w/o a thermostat but still overheats. Has anyone had problems with the same setup as mine or is the source of the problem somewhere else? could it be the head gasket?
Modified by agent marlon at 2:04 AM 6/17/2003
Old Jun 16, 2003 | 04:50 PM
poison's Avatar
Default Re: overheating problems! please help! (agent marlon)
It could be the headgasket. Are you burning any coolant at all, or leaking any?
Make sure thermostat is good, make sure the cooling fan turns on, and also make sure there is good flow through out the water system.
Do a complete flush, with the Heater Core Valve open, and flush the whole system making sure it flows fine.
Old Jun 16, 2003 | 05:15 PM
Default Re: overheating problems! please help! (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">It could be the headgasket. Are you burning any coolant at all, or leaking any?
Do a complete flush, with the Heater Core Valve open, and flush the whole system making sure it flows fine.</TD></TR></TABLE>
where is this Heater Core Valve?
Old Jun 16, 2003 | 05:17 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agent marlon &raquo;</TD></TR><TR><TD CLASS="quote">
where is this Heater Core Valve?</TD></TR></TABLE>
If you turn the climate control to hot, it should open the heater core valve. It is located right under the intake manifold by the EVAP canister.
Old Jun 16, 2003 | 05:25 PM
JV's Avatar
JV
Who?
You either got a bum thermostat or didn't bleed the system correctly. Do what poison said and let us know what happens...
Old Jun 16, 2003 | 05:27 PM
93delsol's Avatar
New User
My car was overheating for awhile. I couldn't figure out what it was so i took it to a dealer. Apparently my car must have hit a bump or something a hose got crimped so not as much fluid was going through. Who would have ever thought. You might want to check the lines if your car is lowered
Old Jun 16, 2003 | 05:29 PM
Default Re: overheating problems! please help! (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">You either got a bum thermostat or didn't bleed the system correctly. Do what poison said and let us know what happens...</TD></TR></TABLE>
how do i know if the system is flowing correctly?
Old Jun 16, 2003 | 05:35 PM
poison's Avatar
how do i know if the system is flowing correctly?</TD></TR></TABLE>
drain the system and flush it with clean water. also use coolant flush inside to get rid of any carbon build up.
You just simply put the hose into the thermostat housing with the thermostat out of the motor, and it will flow out the other end of the motor.
The coolant flush system will burn any carbon build up.
Old Jun 16, 2003 | 05:40 PM
knifesports's Avatar
Does your fan turn on? if it does do what poison said and flush it.
StupidSlowRSX
Dec 17, 2007 07:00 PM
KeEpxiTxLiTt
Nov 17, 2007 11:32 AM
02CivicXer
Honda Civic (2001 - 2005)
Sep 18, 2007 06:37 PM
mightyone
Jun 28, 2003 01:26 PM
