DPFI to MPFI Swap Lots Of Questions
Ok I have decided that since I need a new Fuel Injection System I might aswell go and upgrade my DX to an Si one. Now after alot of searching I found a complete setup for the MPFI. Now honestly I dont know much about stuff on CRX engines. I can do all of the bolt on mods but when you get down into sensors, wiring, etc it like looking at a blank piece of paper.
So who has done it? How much is the MPFI worth? I can get one for $150 CDN which is about $110US. Is that a good deal? Should I keep looking around? Is there a place online where I can get the swap details? How long will it take me? Should I just give up before I start? Are there other MPFIs that will work with my CRX engine, like a 92-95 Civic? Where are my pants?
CRX Forum
CRX Forum
parts list
88-91 si or hf dizzy (has cylinder positioning sensor)
88-91 pm6 ecu ( 90-91 if you want to chip it)
88-91 si intake mani (have seen people do d16y8 manifolds)
injector resistor box
throttle body
all sensors on manifold and throttle body
there is a few places online that have a write up about the mpfi swap. do a archive search in this forum for mpfi, there is a lot of good info and diagrams around on here.
btw have you checked your body for your pants?
throttle body
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt j »</TD></TR><TR><TD CLASS="quote">
88-91 si or hf dizzy (has cylinder positioning sensor)</TD></TR></TABLE>
The Distrubutor Right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt j »</TD></TR><TR><TD CLASS="quote">88-91 pm6 ecu ( 90-91 if you want to chip it)
throttle body
I can get all of these from a 89 CRX Si right? This is the car that I will be getting the MPFI from.
Thanks for your help. I will check it out online and do some searching.
CRX Forum
throttle body
CRX Forum
yeah u can use it forma 89 crx si. u can also go on yahoo and search for the mpfi swap. i actually did it myself about a month ago, and it wasnt that hard
OldGeezer
12
Feb 24, 2002 07:08 PM
