horrible clicking / knocking noise from front wheels: a few questions
i assume this is from my axle... which has to be done by now... it's really bad. there is a horrible clicking / knocking noise until i accellerate or brake..
this is the axle right?
i obviously shouldn't drive on this until it's fixed, right?
how much are these going to cost me if i go to autozone or something?
thanks
eric
thanks
eric
usually clicking is cause by torn CV boot, look under the car and see if you see any torn boot and a lot of grease
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sutrusu »</TD></TR><TR><TD CLASS="quote">there is a horrible clicking / knocking noise until i accellerate or brake..
eric</TD></TR></TABLE>
So it goes away if your driving or braking but makes a cliking sound when just idling? Usually its the axle if your turning and its clicking.
no it clicks when i coast... i am pretty sure it's the axle. the boot is torn. how much will it cost to replace the axle?
not much..just get a rebuilt axle from shucks/kragen/checker...lifetime warranty...they work fine.
Get a rebuilt one.
You take off the broken axle and take it in as a "core" and they will charge you probably between $60-75. If you don't give them your broken axles then you will end up paying about $140-150.
Get axles with a lifetime warranty because they go bad a lot.
go to http://www.4bangercity.com and click on how-to's, it'll show you stepbystep on how to change it/them out.
