what would be the signs of bad rings?
Old Jun 15, 2003 | 10:06 PM
ixcryxblood's Avatar
Default what would be the signs of bad rings?
I just put a rebuilt head on my 92 lude si 2.3.. my uncle claims he put everyting on properly and torqued it down correctly. Now im getting a little moisture in the muffler and it still smokes like a blown head gasket. my uncle also claims its not burning coolant, but what else would make it smoke like that? the car has 144k on it........ someone let me know what they think it is or if it sounds like my rings are bad.... t0ny
Old Jun 15, 2003 | 10:08 PM
Default Re: what would be the signs of bad rings? (ixcryxblood)
if it sounds like bad rings, whats some signs of bad rings?
Old Jun 15, 2003 | 10:20 PM
TurboNOSlude's Avatar
do a compression test. It will vary from car to car, but a difference more than 5-10 psi between the cylinders is a good indication of possible bottom end damage.
As for it being your piston rings... I very much doubt it. In an h22/h23 the most common problem in the bottom end is not the rings, but the ring-lands... not a pretty site. I cracked my ring lands when I turboed, the compression was like this
180psi 180psi 65psi 180psi
so it will be obvious if that is the case...
Old Jun 16, 2003 | 05:06 PM
thanks, im takign it in wed. to get it done
PARADOX_sf
Jan 3, 2011 05:42 PM
GTEater
Sep 30, 2010 09:43 PM
lilshady6796
Jun 20, 2009 07:12 PM
Metal Head
Feb 19, 2009 08:37 PM
LSTEG96
Jul 19, 2004 07:47 PM
