clicking on right front side.... when i turn....
Old Jun 15, 2003 | 08:21 PM
dustywebber's Avatar
Default clicking on right front side.... when i turn....
this clicking can be heard anytime i turn.
the noise comes from the right front side.
possibly the brakes? the suspension?
any ideas?
Old Jun 15, 2003 | 08:24 PM
Cottonwoodz's Avatar
Default Re: clicking on right front side.... when i turn.... (dustywebber)
CV-Joint
Old Jun 15, 2003 | 08:33 PM
prelude1897's Avatar
Exactly, you need to replace your axle (CV-Joint)
Old Jun 15, 2003 | 08:42 PM
CDNGolfer's Avatar
I had this happen on my VW. Turned out to be a worn wheel bearing. Although mine was more like a grinding rather than a clicking.
Old Jun 15, 2003 | 08:50 PM
Jonesy69's Avatar
Default Re: clicking on right front side.... when i turn.... (CDNGolfer)
look at your right front suspension area, you'll see a black "boot", basically a rubber thing with grooves in it. Inspect that for dry rotting, and any tears. If its ripped or dry rotted, its your CV joint. They're easy to replace, and arent really expensive.
Old Jun 15, 2003 | 08:56 PM
LudeyKrus's Avatar
Default Re: clicking on right front side.... when i turn.... (Jonesy69)
i've had this same thing happen and nearly started into the cv joint....until i tried tightening the lug nuts
check the lugnuts and brakes first, that could be the prob.
MyEfSi2Slow
Suspension & Brakes
Oct 29, 2010 09:17 PM
B00ST2nR
Aug 6, 2006 06:32 AM
mikemcberty
Jan 23, 2005 10:16 AM
rustycivic
Mar 7, 2003 09:55 AM
Mugen Dom
13
Aug 20, 2002 11:51 AM
