oil pick up bolts, keep breaking them
Old Jun 15, 2003 | 07:54 PM
civickiller's Avatar
Default oil pick up bolts, keep breaking them
ok so i bought this motor and the oil pan was dented so i took off the pan and the pick up was dented so i got a new one, so i was puttting it back on and when i was torqueing them down to 17 ftlbs i broke hte stock studs, then i went down to ace and got another stud and one bolt, and i cut the head off the bolt and used it as a stud, i tried to torque those back down to 17, but both of them broke.
im confused, anyone had problems like this before or what, am i using hte right torque
help
Old Jun 15, 2003 | 08:16 PM
bossman032's Avatar
Default Re: oil pick up bolts, keep breaking them (civickiller)
let me check that out and get back to you!!!
Old Jun 15, 2003 | 08:21 PM
bossman032's Avatar
Default Re: oil pick up bolts, keep breaking them (bossman032)
suppose to torque at 8LB-FT.
guess why u broke it?
Old Jun 15, 2003 | 08:30 PM
no the mounting bolts say 8, but for the actually tube itsself, my 2 books say 17 for the nuts. cause there are 2 nuts for the tube itself, and 2 mounting bolts, my book says 8 for the mounting bolts and 17 for the tube nuts
Old Jun 15, 2003 | 09:32 PM
JonGP4's Avatar
r u sure its not inch lbs? just don't tighten them down that much. i always say hand tight it good.
Old Jun 15, 2003 | 10:46 PM
Default Re: oil pick up bolts, keep breaking them (JonGP4)
i dont have a problem with not making them torqued down, but im just afraid the vibration might shake it loose and if it comes loose, thats no good
Old Jun 16, 2003 | 12:48 AM
fourthgenhatchB17's Avatar
what i would do, since u keep snapping those studs, is put a little of the light strength thread locker on the new studs and then just snug the nuts down...but of course not 17 ft lbs...jus feel for it u know. It doesnt need to be super tight but just snug and the thread locker should keep them from coming off.
Old Jun 16, 2003 | 04:58 AM
keithv's Avatar
Default Re: oil pick up bolts, keep breaking them (fourthgenhatchB17)
17 ft-lbs sure sounds like alot for a 10mm bolt. i don't have my manual in front of me, but i don't think that is the right spec.
Old Jun 16, 2003 | 05:20 AM
EG8R's Avatar
Default Re: oil pick up bolts, keep breaking them (keithv)
17 lbs is what I just read as well....
Old Jun 16, 2003 | 05:23 AM
keithv's Avatar
Default Re: oil pick up bolts, keep breaking them (mr. skelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. skelly &raquo;</TD></TR><TR><TD CLASS="quote">17 lbs is what I just read as well....</TD></TR></TABLE>
what size head are these bolts? 10mm? or 12mm?
Old Jun 16, 2003 | 10:01 AM
well its not a bolts its a stud with a nut. but the nut itself is a 10mm nut.
Old Jun 16, 2003 | 05:50 PM
well i called honda and they told me it was 8ftlbs not 17, and they said my book is wrong
Old Jun 16, 2003 | 05:54 PM
i called honda and they said that my book is wrong and that it is 8ftlbs
Old Jun 20, 2003 | 05:49 PM
bossman032's Avatar
LOL.
haha
Old Jun 20, 2003 | 05:58 PM
4crx4me's Avatar
Yea the book says 17 lbs.
But all the other accys. that bolt to the block are like 8 -9 or 13 lbs.
Oil pan bolts, oil pump bolts, oil press. sender,and it's the same aluminum.So i guess honda printed the wrong spec.
Old Jun 20, 2003 | 09:19 PM
kanzenr91si's Avatar
Default Re: oil pick up bolts, keep breaking them (4crx4me)
what book do you have? my helms says 8
Old Jun 20, 2003 | 09:33 PM
4crx4me's Avatar
Default Re: oil pick up bolts, keep breaking them (kanzenr91si)
I have a 1988 CRX and a 1990 CRX. Both Helms.
for the oil pick-up bolts,they both show 17 ft-lbs.
jayupark
Dec 3, 2013 06:07 PM
Cprace1
Sep 25, 2007 06:53 PM
jomama
Feb 25, 2007 02:00 PM
92integra-R
Dec 21, 2006 01:33 PM
92-LS-Civic
Oct 7, 2004 07:47 AM
