aftermarket HID kit + no splashguard = a good idea??
Old Jun 15, 2003 | 05:44 PM
JDM_ITR's Avatar
Default aftermarket HID kit + no splashguard = a good idea??
i just recently purchased a used set of HIDs, but im hesitant to install them because i dont have any splashguards on my car right now. Are the ballast usually waterproof for most aftermarket HID kits? Im not even sure what brand mine is, but i got it for a really good deal - and it looks nice. What do u guys think? Should i wait until i put in some splashguards, or would it be ok to install now?
Old Jun 15, 2003 | 05:57 PM
jdmspoonitr's Avatar
Default Re: aftermarket HID kit + no splashguard = a good idea?? (JDM_ITR)
I'm pretty sure they are not water proof. Where did you plan on mounting the ballasts? Depending on the location it might or might not matter. Most people that prefer the clean look stick it behind the fender. So if you have a fender liner you should be ok there.
Old Jun 15, 2003 | 06:01 PM
Jason's Avatar
people have also wrapped them in plastic or put them in bags to prevent them from getting wet...if you're that worried about it...
Do you need a splashguard? (if you're talking about the big plastic one under the front of the car?) I have one if you're interested
Old Jun 15, 2003 | 06:54 PM
JDM_ITR's Avatar
Default Re: aftermarket HID kit + no splashguard = a good idea?? (Jason)
no i have a splash guard, just havent installed them yet. how about siliconing the ballast? has anyone done that?
Old Jun 15, 2003 | 08:23 PM
Buckshot's Avatar
i have washed my engine a few times and got everything wet...everything still works
Old Jun 15, 2003 | 10:44 PM
GettaluvR's Avatar
New User
Default Re: aftermarket HID kit + no splashguard = a good idea?? (Buckshot)
my came with a platic box so no need to worry
Old Jun 16, 2003 | 01:56 AM
nek0's Avatar
Default Re: aftermarket HID kit + no splashguard = a good idea?? (GettaluvR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GettaluvR &raquo;</TD></TR><TR><TD CLASS="quote">my came with a platic box so no need to worry </TD></TR></TABLE>
That's just a non-conductive casing and doesn't mean it's water proof.
Question about the topic, as long as you're installing it away from a direct view of the ground, you should be fine. If you're worried you can either wrap it with plastic or build a small shield near the bottom to avoid any water from splashing against it.
Old Jun 16, 2003 | 10:55 AM
GettaluvR's Avatar
New User
Default Re: aftermarket HID kit + no splashguard = a good idea?? (nek0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nek0 &raquo;</TD></TR><TR><TD CLASS="quote">
ya but it seals pretty good !
Old Jun 16, 2003 | 01:51 PM
py1188's Avatar
do you mean fender liner or splahguard??
Old Jun 16, 2003 | 01:57 PM
type r 01-1063's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buckshot &raquo;</TD></TR><TR><TD CLASS="quote">i have washed my engine a few times and got everything wet...everything still works </TD></TR></TABLE>
I remove the wholel ballast and replace it with the stock bulbs to seal the headlight housing. I'm not willing to take any chances on messing up my $400 HID system.
Old Jun 16, 2003 | 02:37 PM
JDM_ITR's Avatar
Default Re: aftermarket HID kit + no splashguard = a good idea?? (py1188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">do you mean fender liner or splahguard??</TD></TR></TABLE>
i must be stupid, but i thought fender liner and splash guard was the same thing... any ways, have you guys ever tried of heard of anyone siliconing the ballast and igniter?
Old Jun 16, 2003 | 09:37 PM
JDM_ITR's Avatar
DJNauTicz
Lighting
23
Sep 5, 2007 10:06 AM
4_door_eg
18
Apr 3, 2007 01:24 PM
IMPACT
Jan 4, 2007 08:26 PM
Euro98ITR
Jan 4, 2006 11:29 AM
vtec94
May 8, 2002 08:35 AM
