Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
anyone run more neg. camber on the left side?
Old Jun 15, 2003 | 04:25 PM
577HondaPrelude's Avatar
Default anyone run more neg. camber on the left side?
I was playing with the car today and thought I would add some extra neg. camber to the left front trie. I'm going to try this for the next track day just to see how it does. Anyone run like this all the time?
My settings are now:
Front Left: -2.5
Front Right: -1.75
Rear Left: -1.5
Rear Right: -1.5
Front toe: 3mm out
rear toe: ~0
Old Jun 15, 2003 | 10:00 PM
manveer's Avatar
Default Re: anyone run more neg. camber on the left side? (57STS)
Are you trying to compensate for the way the driver's weight affects the alignment...?
What is your reasoning on why you think this will improve handling?
Old Jun 16, 2003 | 07:46 AM
Evan55's Avatar
Default Re: anyone run more neg. camber on the left side? (manveer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manveer &raquo;</TD></TR><TR><TD CLASS="quote">Are you trying to compensate for the way the driver's weight affects the alignment...?
What is your reasoning on why you think this will improve handling?</TD></TR></TABLE>To compensate for driver weight you would actually have a little less camber on the left side, since the suspension will compress due to driver weight.
Im guessing that he is doing this because there are more right hand corners one typical clockwise run track than left hand corners.
Personally, I wouldnt want my car to handle differently on left handers than right handers. Not to mention the unpredictable nature.
Although, in practice, I think you will find that the different camber numbers wont affect your handling that much. Last time I had my car up on the rack the camber was -1.5 on one side, and -2.4 on the other. (supposed to be -2.0 on each side) Before that I hadnt noticed handling to be too far off.
Old Jun 16, 2003 | 08:29 AM
Default Re: anyone run more neg. camber on the left side? (elgorey)
No! I'm trying to compensate for the fact that most turn are right had turns, and that the outside of the left tire is wearing much faster than the inside. The front right tire is wearing pretty evenly with only -1.5 deg. camber, but the front left was not. Was just an idea is all
Maybe it's a bad idea?
Old Jun 16, 2003 | 02:21 PM
manveer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey &raquo;</TD></TR><TR><TD CLASS="quote">To compensate for driver weight you would actually have a little less camber on the left side, since the suspension will compress due to driver weight.</TD></TR></TABLE>
That's what I was thinking...and why I was confused.
FalkenSiR
Suspension & Brakes
Jun 6, 2006 11:06 AM
TurboEM1
Suspension & Brakes
10
Mar 31, 2006 05:12 AM
Francesco
Honda S2000
32
Jan 30, 2006 08:33 PM
Understeer
Jul 11, 2005 05:09 AM
whole9
Mar 23, 2005 06:30 AM
