Need help: Oil Pan Nut size and Radiator Host ID.
Old Jul 21, 2001 | 10:20 AM
nEoMuGen's Avatar
Default Need help: Oil Pan Nut size and Radiator Host ID.
Thanks tor those of you that actually had the patience to read my previous post about the omori gauges, now here is a more simpler version, I just need to know the
1. Side OEM Oil Pan size: Mxx = x.xmm. ( I hope it's neither M14 = 1.5mm or M12 = 1.25 for a perfect fit )
2. The radiator Hose ID. ( I will check later myself, and hopefully finds it )
If I can have these two numbers, I can have my car done. Although no one replied my previsou post, but surprisingly, the omori representative saw my post and emailed me back. Thanks Mike! Here is his reply, for those who plan to help me out, it provides more detail:
__________________________________________________ __________________________________________________ ____________________
"Omori Mail Order Services Centre, Malaysia
Dear Sir,
This is Michael, from Omori, Malaysia.
We readed your meassage in the Hondatech and knowing that you do have the installation problem.
For your information, it is recommended that you install the Oil Temperature Sender to the Oil Pan side.
There has a NUT or Plug located at the Oil Pan side which used for Oil exchange , just remove the said nut and measure the "Thread Size" to determine the Nut /Plug
size .
If the size is at M14 P=1.5, the Oil temperature sender will fit to this OEM place
Key to read : M12 = 12mm size in diameter ( The Nut/Plug Diameter size in mm )
P=1.5 mean the distance of the Thread in mm
example : P 1.5 = 1.5mm ( distance of the "Thread size " )
Your local Mechanic should know the actual size for the Oil Pan Nut. Call you local Omori Dealer for the necessary adapter if necessary.
( Remark : I think the OEM Nut/Plug might be the same size ( M14 P1.5 ) , if so, you maybe able to install this Oil Temperature sender to your Oil Pan without any
additional adapter.
Support if the size of the nut is different than the M12 P=1.25 and M14 P=1.5, you may need to make an adapter which fit or same with the Oil Pan Nut/Plug to convert
the M14 P1.5 ( Omori Oil Temperature Size) to fit to the Oil Pan.
Regarding the Water Temp sender :-
it is recommended that you used our Water Temperature Adapter ( Part No, P171 - P178 available in different size for an easy installation )
This adapter allowed an easier installation , all we need is your Radiator hose ID to select the correct size. The installation is very easy by cutting your Radiator and fit
this adapter to, after that, Install the water temperature sender to the adapter, and run the tubing through the firewall to the interior, that is, no modifly needed as well as a
new adapter.
Again, we appreciate your interest and support for the Omori Gauges and should we can of further assistance, please do not hesitate to contact us.
Sincerely Yours
Michael Pang
Malaysia
url : http://www.omorimeter.com"
[Modified by nEoMuGen, 7:22 PM 7/21/2001]
Skwizzlebang
Jan 26, 2011 03:27 PM
rdeezy78
Nov 2, 2009 06:45 PM
mykeshonda
Sep 28, 2004 06:04 AM
monicle
11
Oct 13, 2003 11:48 AM
