Air conditioning problem with 97 gsr!
Old Jun 14, 2003 | 10:04 PM
m R g S r's Avatar
Default Air conditioning problem with 97 gsr!
Hey guys im new to the fourms and first off I'd like to say i love my new integra. There is an exception however, my air conditioning has a major problem. Now it works fine, and the air comes out ice cold, but after I use the system for any period of time, or even a few minutes, water starts pouring into the car from under the passenger side dash. At first it was only dripping (because I didn't use it that much) but today I pulled out my mat and there was 1/4" of water soaking my passenger side carpet. Also if I go into a turn hard the water will drip onto my feet! This sucks and I really need it fixed soon. I'm pretty handy so im sure i'd be able to fix it, i just need some insight on what it can be. I hope you guys can help me out.....
Old Jun 14, 2003 | 10:49 PM
__37__'s Avatar
Default Re: Air conditioning problem with 97 gsr! (m R g S r)
i have this problem too, but i havent taken the time to figure it out. i would be interested to see what anyone has to say about this.
Old Jun 14, 2003 | 11:36 PM
97hb's Avatar
There is a dump tube for the ac system on the passenger side that lets all the condensation out of. If you look in the engine bay right below the battery you will see the tube going to the ground. Mine clogged with some gunk and I used a coat hanger to unclog it. No water on the ground now. Also be careful as the water building up can short the ecu out if there is alot.
Old Jun 15, 2003 | 04:35 AM
IntEGNYC's Avatar
Default Re: Air conditioning problem with 97 gsr! (97hb)
good Looking out.
Old Jun 15, 2003 | 05:44 AM
SicNA94TegGsR's Avatar
Swollen Member
Check the A/C Drain tube, should be located under the car around that area, sticking out alittle bit, from the floor pans/fire wall....just blow it out with some compressed air, and the blockage should be removed.
Old Jun 15, 2003 | 08:44 AM
__37__'s Avatar
Default Re: Air conditioning problem with 97 gsr! (SicNA94TegGsR)
thanks
B16 IIgen
Sep 7, 2006 11:07 PM
the.hamburglar
Dec 29, 2003 08:00 AM
Black-Stang
Jul 6, 2003 05:14 AM
95integraTurbo
Feb 13, 2002 08:37 AM
